  • FootNote Electric Guitar 5 Watt Amp Assembly with Power Supply
CLEARANCE FootNote Electric Guitar 5 Watt Amp Assembly with Power Supply
Factory Buyouts
Part #249-404
Factory Buyouts
Part #249-404
You can build your own practice amp, to your liking, for a mere fraction of the price you'd pay for a "store-bought" model. In this bundle, you get a 5 watt amp module packed with extras, and a 9V power supply to power it up! We have a very limited quantity of these components available, so act fast!
  • Build it yourself, just the way YOU want it!
  • 5 watt amp module with cable tester and eight 9V power outputs
  • Headphone output and auxiliary input
  • External speaker output and line output
  • Buyout - extremely limited supply available
These components come from a manufacturer whose name is very well known among those in the music industry (and many other industries), for a finished product that can be found in most major music stores. As it happens, they built way too many units for their needs, and sold the excess to us for pennies on the dollar just to get them out of their warehouse.
As a result of this fortuitous turn of events, you can now acquire some very specialized components to create a practice amp and/or pedalboard of your own design, for WAY less than you'd pay for a finished product that may or may not be exactly what you want for your own personal taste.
The FootNote amplifier module's main feature is a clean 5 watt amp with bass, treble, and volume control in a convenient form factor, but it doesn't stop there. With the FootNote, you also get a headphone output for private practice or listening, and an external speaker output to drive another speaker (4 ohm minimum impedance). But wait, there's more! You also get a line level output to feed your shredness directly to your mixing console, recorder, what have you. There is an auxiliary input for your iPod, smartphone, or other media device, so you can jam along with all your favorite tunes, AND, there's a super-handy cable tester built right in, so you never have to worry about bringing down the energy of your performance due to a bad cable.
As if all that weren't already awesome enough, there is more. The FootNote operates on 9 VDC (AC adapter included), has an optional input for battery power, and has eight (8) DC power output jacks built in to power your effects pedals!
Specifications: • Amp module dimensions: 12" L x 3-1/2" H x 2-9/16" D • Cutout: 11-9/16" L x 2-5/8" H • Power output: 5 watts • Inputs: 1/4" guitar / pedal; 3.5 mm aux; 1/4" x 2 cable tester • Outputs: 1/4" line; 1/4" ext speaker; 8 x 3.5 mm 9 VDC (center negative polarity) • Controls: main power on/off; line out on/off; volume, bass, and treble • Power input: 9 VDC (120V/60Hz AC/DC adapter included) • Power output: 9 VDC x 8 (center negative polarity).
BrandFactory Buyouts
Part Number249-404
UPC848864060842
Weight3
MONSTER DEAL
OF THE WEEK
$23.98 EACH
SAVE 20%
Lepai LP‑2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
