  • FaitalPRO FD371 Bullet Super Tweeter 8 Ohm
FaitalPRO
Part #294-1000
FaitalPRO
Part #294-1000
Model: FD371
Choose the FD371 bullet tweeter from FaitalPRO for use in two-way speakers and applications that require controlled directivity, high output, and a smooth frequency response.
  • Efficient design for high output and a compact size
  • Polymer diaphragm for extremely smooth frequency response
  • 40° by 40° dispersion for a tight, controlled directivity
  • Aluminum waveguide
  • Made in Italy
Your Price: $222.00
Only 3 In Stock
More due any day
FaitalPRO's FD371 bullet super tweeter, complete with an aluminum 40° conical dispersion horn, is not your typical bullet tweeter. A ferrite ring magnet assembly drives a 37 mm Kapton voice coil with ketone polymer annular ring diaphragm, resulting in an average sensitivity of 107 dB and smooth frequency response from 2.6 to 20 kHz, with an impressive minimum recommended crossover frequency of 2.6 kHz (using a -12 dB/octave filter). Made in Italy.
Specifications: • Power handling: 35 watts RMS with recommended crossover of 2,600 Hz, 12 dB/octave slope • VCdia: 1.46" • Impedance: 8 ohms • Frequency response: 2,600-20,000 Hz • SPL: 107 dB 1W/1m • Dimensions: A: 4.54" (4.02" across the flats), B: 3.58", C: 2.89".
BrandFaitalPRO
ModelFD371
Part Number294-1000
UPC848864011196
Weight2.9
Diaphragm MaterialPoly / Mylar
Power Handling (RMS)35 Watts
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
