  • FaitalPRO 15PR400 15" Neodymium Professional Woofer 8 Ohm
FaitalPRO
Part #294-1271
FaitalPRO
Part #294-1271
Model: 15PR400
Choose FaitalPRO's 15" 15PR400 woofer to replace or upgrade the woofer in your speaker cabinet. A flat frequency response to 4,000 Hz and high sensitivity of 99 dB (1W/1m) allows it to match well with nearly any horn driver.
  • Lightweight design weighs just under 8 pounds
  • 99 dB sensitivity due to high-energy neo motor
  • Durable cast-aluminum frame
  • Ultra-linear frequency response
  • Made in Italy
Your Price: $342.00
Order in the next 3 hr 19 min to ship today. Details
11In Stock
With high sensitivity and a ruler-flat frequency response from 35 Hz to 4,000 Hz, FaitalPRO's 15PR400 15" woofer is perfect for replacing and upgrading tired, worn-out woofers in small to large-sized, vented two-way speakers. The 15PR400 is a great choice for live sound and high output home audio speakers.
An eight-spoke, cast-aluminum frame adds structural integrity, while the treated paper cone and accordion cloth surround can withstand years of constant use. The 400 watt RMS power handling rating is made possible by the use of a 3" voice coil on a glass fiber former. A neodymium slug motor keeps weight low, just under 8 pounds. Made in Italy.
BrandFaitalPRO
Model15PR400
Part Number294-1271
UPC848864008301
Weight10.85
Nominal Diameter15"
Bolt Circle Diameter14.72
Power Handling (RMS)400 Watts
Power Handling (MAX)800 Watts
Frequency Response35 to 4,000Hz
Sensitivity99dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)35Hz
DC Resistance (Re)5.1Ω
Voice Coil Inductance (Le)0.75mH
Mechanical Q (Qms)6.02
Electromagnetic Q (Qes)0.34
Total Q (Qts)0.32
Compliance Equivalent Volume (Vas)7.88ft³
Mechanical Compliance of Suspension (Cms)0.24mm/N
BL Product (BL)16.7T·m
Diaphragm Mass Inc. Airload (Mms)85.2g
Maximum Linear Excursion (Xmax)5.75mm
Surface Area of Cone (Sd)805cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter15.47"
Baffle Cutout Diameter13.94"
Depth6.5"
Sealed Volume1.75ft³
Sealed F386.7Hz
Vented Volume3.25ft³
Vented F343.3Hz
