  • FaitalPRO 10FE200 10" Professional Woofer 4 Ohm
FaitalPRO
Part #294-1200
FaitalPRO
Part #294-1200
Model: 10FE200
FaitalPRO's economical 10FE200 10" woofer has the output and linear frequency response needed to use it as a large format midrange. The 4 ohm impedance also makes it great for use in high output car audio applications.
  • Stamped steel frame and cloth accordion surround
  • High 96 dB sensitivity
  • Flat frequency response from 50 to 4,500 Hz
  • Made in Italy
Your Price: $71.00
Order in the next 15 hr 30 min to ship today. Details
Only 4 In Stock
More due any day
The 10FE200 10" woofer from FaitalPRO features a high sensitivity of 96 dB (1W/1m), extremely flat frequency response from 50 to 4,500 Hz, and a shallow profile making it a natural choice for use as a large format midrange or midbass in multi-way professional speaker cabinets.
Good off-axis response and a mid-Qts rating of 0.5 allows the 10FE200 to be used in small and large-sized ported or sealed cabinets as a woofer. A 4 ohm impedance makes this version of the 10FE200 a great selection for high output car audio systems. Durability is insured by the treated paper cone and accordion surround. Made in Italy.
BrandFaitalPRO
Model10FE200
Part Number294-1200
UPC848864008622
Weight5.75
Nominal Diameter10"
Bolt Circle Diameter9.6
Power Handling (RMS)150 Watts
Power Handling (MAX)300 Watts
Frequency Response50 to 4,500Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter1.46"
Resonant Frequency (Fs)55Hz
DC Resistance (Re)
Mechanical Q (Qms)9
Electromagnetic Q (Qes)0.52
Total Q (Qts)0.5
Compliance Equivalent Volume (Vas)1.87ft³
Mechanical Compliance of Suspension (Cms)0.34mm/N
BL Product (BL)7T·m
Diaphragm Mass Inc. Airload (Mms)24.8g
Maximum Linear Excursion (Xmax)4.62mm
Surface Area of Cone (Sd)332cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Overall Outside Diameter10.11"
Baffle Cutout Diameter9.13"
Depth4.02"
Sealed Volume1.2ft³
Sealed F387.4Hz
Vented Volume1.63ft³
Vented F355.6Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
