  • Eminence Patriot Cannabis Rex 10" Guitar Speaker 8 Ohm
Eminence Speaker
Part #290-4820
Eminence Speaker
Part #290-4820
Model: Cannabis Rex 10
Due to high demand Eminence created the 8 ohm Cannabis Rex 10. This hemp cone 10" speaker offers warm, smooth, clean, and full tone, but with high end definition.
  • Provides a warm, smooth, and detailed tone that only a hemp cone can deliver
  • 99 dB efficiency for high output without tons of power
  • Perfect for use in 2 and 4 x 10" cabinet designs
  • Front and rear gaskets ensure a good seal to you enclosure
Your Price: $119.99
MSRP: $149.99
Save $30.00 (20%)
Order in the next 9 hr 56 min to ship today. Details
Only 2 In Stock
Due to high demand Eminence created the Cannabis Rex 10, this hemp cone 10" speaker offers warm, smooth, clean, and full tone, but with high end definition – just like its big brother. Great to tame a bright amp and/or guitar. With an even-hung voice coil, the Cannabis Rex 10 provides incredible efficiency (over 99 dB) to produce powerful output that that is suitable for both bass and guitar amps.
Electric guitars, guitar amplification, and the birth of Rock-n-Roll in the 1950's collectively established a new use for loudspeakers. Speaker choices were limited in those days and amplifier manufacturers had to purchase products that were common to other applications. Usually, this meant a low-power speaker, often with an Alnico magnet, and limited cone and coil travel.
Due to the nature of the speaker's construction, the sound of the guitar and amplifier combination was impacted by the speaker design. Amplified guitar was a bit more aggressive duty than most other speaker applications at the time and the speakers were frequently challenged in terms of their mechanical movement and linearity. Guitarist learned how to control this non-linearity and use the resulting tonal characteristics to their advantage. Speaker break-up became cool and was a desired feature by most guitarists. The great guitar tones we know now are a result of those events.
Although there are a multitude of distinctive guitar speaker tones available today, they can be broken down into two main categories. We have Marshall and Celestion to thank for the distinctively "British tones" that we are so familiar with. Fender, Peavey, and SLM (Crate/Ampeg) worked with speaker companies like Eminence, Oxford, CTS, JBL, and Electro-Voice to establish tones that are distinctively "American".
Eminence is proud to present the Patriot™ and Red Coat™ series of guitar speakers. Incorporating both British and American cone technology into speakers that are manufactured in the USA gives us the ability to provide you with virtually any tone you desire. Be it British or American, clean or dirty, big bass or screaming highs, we have a speaker that will allow you to "Pick Your Sound".
To help you select the right Eminence guitar speaker, check out Eminence's Tone Guide.
BrandEminence Speaker
ModelCannabis Rex 10
Part Number290-4820
UPC876358004027
Weight8
Nominal Diameter10"
Power Handling (RMS)50 Watts
