  • Eminence Legend B810 10" Bass Guitar Driver 150W 32 Ohm
Eminence Speaker
Part #290-468
Eminence Speaker
Part #290-468
Model: Legend B810
The Legend B810 is a 32 ohm, 10" stamped frame bass guitar driver. A true classic design with some important updates.
Your Price: $124.99
MSRP: $154.99
Save $30.00 (19%)
Order in the next 2 hr 47 min to ship today. Details
Only 1 In Stock
More due any day
The Legend B810 is a 32 ohm, 10" stamped frame bass guitar driver. A true classic design with some important updates: an M-roll surround for higher excursion and less cone breakage, a double-dipped cone apex for an extra-strong cone neck, and a bumped back plate for greater voice coil travel before damage. Eminence's B810 offers classic sound with some modern features added to make a driver that will sound great and last a long time. Works well in small sealed enclosures and in some vented applications. The ultimate driver for classic 8 x 10" bass guitar cabinets. Use the Legend B810 four at a time, connected in parallel, to get an 8 ohm load. Eight of them connected in parallel will result in a 4 ohm load.
Specifications: • Power handling: 150 watts RMS/300 watts max • VCdia: 2" • Le: 2.72 mH • Impedance: 32 ohms • Re: 27.5 ohms • Frequency range: 49-5,100 Hz • Magnet weight: 30 oz. • Fs: 52.07 Hz • Sensitivity: 92.7 dB 1W/1m • Vas: 2.34 cu. ft. • Qms: 13.91 • Qes: 0.68 • Qts: 0.65 • Xmax: 4.7 mm • Dimensions: Overall diameter 10.11", Cutout diameter 9.13", Depth 4.08".
BrandEminence Speaker
ModelLegend B810
Part Number290-468
UPC876358001705
Weight8
Nominal Diameter10"
Power Handling (RMS)150 Watts
Impedance32Ω
