  • Eminence H14EA 1.4" Cast Aluminum Exponential Horn 60x40 4-Bolt
Eminence Speaker
Part #290-5612
Eminence Speaker
Part #290-5612
Model: H14EA
Cast aluminum construction and skilled use of finite element analysis ensure the Eminence H14EA 1.4" exponential horn delivers reliable, tightly controlled sound reproduction in portable and permanent applications.
  • FEA-optimized aluminum design is durable and hi-fi sounding
  • High gain design is ideal for long throw applications
  • Controlled dispersion reduces interactions between adjacent loudspeakers
  • Heat sink property provides additional cooling to hardworking high frequency drivers
  • Industry standard 1.4" throat, 4-bolt mounting for large format HF drivers
The Eminence H14EA 60° x 40° 1.4" horn features durable cast aluminum construction and an exponential flare geometry that optimizes acoustical loading and high frequency efficiency. Although its mouth area requires minimal baffle space, the H14EA horn operates down to 600 Hz and provides excellent functionality when deployed in venues of any size. A 60° x 40° dispersion pattern maintains maximum directivity and gain, keeping the horn's coverage well-controlled and focused.
In addition to the aluminum horn body's high mechanical strength, its ability to couple to high frequency drivers thermally results in a measured 25°F reduction in operating temperature. The utility of this heat sink advantage is especially obvious when using neodymium drivers, and results in improved reliability and reduced power compression.
Thanks to extensive FEA-optimized testing, as well as extensive listening evaluations, the Eminence H14EA reproduces its intended frequency range without coloration, diffraction effects, or distortion. Recommended for pro audio multi-way loudspeakers, stage monitors, and high output cinema systems.
Specifications: • Horn type: Exponential • Minimum frequency: 600 Hz • Nominal dispersion: 60° H x 40° V • Throat diameter: 1.4" • Mounting type: 4-bolt • Dimensions: 12.6" W x 7.5" H x 7.9" D • Cutout dimensions: 11.3" x 6.1" • Weight 4.8 lbs.
BrandEminence Speaker
ModelH14EA
Part Number290-5612
UPC876358002610
Weight4.3
ConstructionAluminum
Entry / Throat Diameter1.4"
Mounting Type4-Bolt
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
