  • Eminence Delta Pro-12A 12" Cast Frame Driver
Eminence Speaker
Part #290-510
Eminence Speaker
Part #290-510
Model: Delta Pro-12A
The Eminence Delta Pro-12A 12" cast frame speaker is recommended for professional audio in sealed, vented, and horn-loaded enclosures. Ideal for full-range, mid/hi, and monitor wedges. Extremely efficient through the midrange, but with a surprisingly strong bass kick as well.
  • Kapton coil former
  • Polyamide-imide coated copper voice coil
  • Die-cast aluminum frame
  • Ferrite magnet
  • Vented and extended pole piece
  • Paper cone
  • Cloth M-roll surround
Your Price: $159.99
MSRP: $194.99
Save $35.00 (18%)
8In Stock
The Eminence Delta Pro-12A 12" cast frame speaker is recommended for professional audio in sealed, vented, and horn-loaded enclosures. Ideal for full-range, mid/hi, and monitor wedges. Extremely efficient through the midrange, but with a surprisingly strong bass kick as well. Similar to EVM12L-BL guitar speaker. Suitable replacement for EAW FR129Z, EAW SM122e, 804058, and LC1243. Made in the USA. 7-year manufacturer's warranty!
BrandEminence Speaker
ModelDelta Pro-12A
Part Number290-510
UPC876358000333
Weight17.9
Nominal Diameter12"
Power Handling (RMS)400 Watts
Power Handling (MAX)800 Watts
Frequency Response52 to 4,500Hz
Sensitivity99.2dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)51Hz
DC Resistance (Re)5.71Ω
Voice Coil Inductance (Le)0.84mH
Mechanical Q (Qms)7.56
Electromagnetic Q (Qes)0.37
Total Q (Qts)0.35
Compliance Equivalent Volume (Vas)2.89ft³
Mechanical Compliance of Suspension (Cms)0.21mm/N
BL Product (BL)15.3T·m
Diaphragm Mass Inc. Airload (Mms)48g
Maximum Linear Excursion (Xmax)4.6mm
Surface Area of Cone (Sd)532.4cm²
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter12.38"
Baffle Cutout Diameter11.07"
Depth6.22"
Sealed Volume1.3ft³
Sealed F3130Hz
Vented Volume1.9ft³
Vented F362Hz
MONSTER DEAL
OF THE WEEK
$23.98 EACH
SAVE 20%
Lepai LP-2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
