  • Eminence APT-150 Super Tweeter with Horn 100 x 50
Eminence Speaker
Part #290-534
Eminence Speaker
Part #290-534
Model: APT-150
The APT high-power super tweeter possesses extraordinary sensitivity thanks to a phenolic diaphragm, which has unique properties of stiffness and damping. By fluid cooling the voice coil, increased power handling and controlled low frequency behavior are assured.
Your Price: $59.99
MSRP: $79.99
Save $20.00 (25%)
Estimated back in stock 4/11/2025
Alert Me When Available
The APT high-power super tweeter possesses extraordinary sensitivity thanks to a phenolic diaphragm, which has unique properties of stiffness and damping. By fluid cooling the voice coil, increased power handling, controlled low frequency behavior and long-term reliability are assured. The APT-150 super tweeter is pre-mounted on an 100° H x 50° V horn.
Specifications: • Power handling: 45 watts RMS (crossover frequency 3.5 kHz, 18 dB/octave), 85 watts RMS (crossover frequency 5 kHz, 18 dB/octave) • Impedance: 8 ohms • Useable range: 3,500-20,000 Hz • Fs: 2,500 Hz • Recommended crossover: 3,500 Hz • Mfg. #APT-150 • Dimensions: 4-1/2" H x 7-1/2" W x 5" D • Cutout dimensions: 3-3/8" H x 6-5/8" W.
BrandEminence Speaker
ModelAPT-150
Part Number290-534
UPC876358001347
Weight2
Diaphragm MaterialPhenolic
Power Handling (RMS)45 Watts
