  • Parts Express Dual Banana Plug Black
Part #090-471
Part #090-471
Dual banana plugs are for use with test equipment including volt meters and multimeters, frequency generators and counters, and audio devices using banana jacks or binding posts with standard 0.75" center to center spacing.
Your Price: $2.49
MSRP: $3.99
Save $1.50 (38%)
Quantity:Qty: 1-9 $2.49/ea
Quantity:Qty: 10+$2.24/ea
357In Stock
Dual banana plugs have been widely used in the electronics industry since early in the last century. Commonly used with test equipment, dual banana plugs are designed with industry standard 0.75" center to center post spacing. A plastic tag molded to one side of the connector is marked GND so the user can quickly identify the negative side of the connector. An integrated strain relief on one side of the connector holds the cable securely in place. Accepts up to 12 AWG cable and attaches with screw terminals so soldering is not necessary. Nickel plated brass contacts will provide a lifetime of use free of oxidation.
Part Number090-471
UPC844632011498
Weight0.033
Contact PlatingNickel
Style / TypeDual
