  • Double Sided 1/2" x 3/64" Black Mounting Tape 30 ft. Long
Part #350-110
Part #350-110
Secure battery holders, PC boards, and other components in-place with this double sided 1/2" black foam tape. Works perfect as gasket tape for speaker cabinet components too.
  • Only 1 mm thick for an almost invisible hold
  • Double sided adhesion and closed cell foam replaces worn out speaker cabinet gaskets
  • Economical 10 meter (32.8 ft.) roll
Your Price: $5.79
MSRP: $8.99
Save $3.20 (36%)
Quantity:Qty: 1-9 $5.79/ea
Quantity:Qty: 10+$5.21/ea
Order in the next 2 hr 0 min to ship today. Details
Use this 1/2" (13 mm) wide double sided foam tape to keep battery holders and other components from sliding around inside enclosures, or as gasket sealing tape for speaker cabinets. 0.04" (1 mm) thick black foam tape takes up very little space and hides well under PC boards, battery boards, displays, control panels, drivers, and speaker wire terminal cups. 32 ft. roll is great for large projects and its economical price is perfect for smaller jobs. Adhesion to steel is 900g/25 mm minimum and tact is 6 cm.
Part Number350-110
UPC848864060637
Weight0.15
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
