Dayton Audio UMII10-22 Ultimax II 10" DVC Subwoofer 2 Ohm Per Coil
- A large aluminum shorting cap and sleeve help keep inductance linear to guarantee minimal distortion
- The rigid yet lightweight woven carbon fiber cone delivers quick, detailed, and accurate response
- With ±20 mm xmax, you can expect powerful and deep bass response, taking your audio experience to the next level
- Equipped with a 4-layer 2-1/2" flat wound voice coil that can handle up to 600 watts RMS
- The frame and motor include extensive venting ensuring efficient heat dissipation for consistent and reliable operation, while minimizing power compression
- Dual spiders maintain cone linearity even at extremely high excursion levels, providing peak audio performance at all times
- Optimized for compact sealed enclosures, but capable of exceptional low frequency extension in vented designs - offering you the freedom to create the perfect audio setup
We'll send you an email when Dayton Audio UMII10-22 Ultimax II 10" DVC Subwoofer 2 Ohm Per Coil is back in stock or available for preorder.
