  • Dayton Audio Hidden Garden Outdoor Landscape Speaker System
Read 1 Review or
Dayton Audio
Part #310-039
Dayton Audio
Part #310-039
Read 1 Review or
Spring is here, the warmth is welcome, and everywhere you go you can hear the calls of the birds and the bees. Join them outside with this outdoor speaker bundle brought to you by Dayton Audio! This package includes everything you need for installation; excluding the pollen!
  • Convenient all-in-one installation package
  • Compact speaker design fits great in any location
  • Crystal clear sound quality for great listening all around
  • Underground burial wire and waterproof cable connectors included
  • Complete install bundle includes two 4" pendant speakers, one 8" Burial Subwoofer, and all the amplifiers and accessories needed
Your Price: $499.98
MSRP: $699.97
Save $199.99 (29%)
Order in the next 6 hr 11 min to ship today. Details
Dayton Audio DB8 Burial Subwoofer
  • Design: Outdoor Burial Subwoofer
  • Woofer: 8" polypropylene cone with rubber surround
  • Power Handling (RMS): 180 Watts @ 8 Ohms
  • Power Handling (MAX): 400 Watts @ 8 Ohms
  • Frequency Response: 25Hz-300Hz
Dayton Audio WP4BT Pendant Speaker
  • Design: IP66 2-Way Pendant Speaker
  • Woofer: 4" Mineral-Filled Polypropylene
  • Tweeter: 7/8" Fabric Dome
  • Power Handling (RMS): 20 Watts @ 8 Ohms
  • Frequency Response: 60Hz-20KHz
We Got Your Back
Read More
Dayton Audio WP4BT IP66 Pendant Speaker
The Installers Delight
The WP65BT can be used for both commercial and residential applications. The speaker features an integrated 70/100V transformer with multiple taps. The speaker also has an 8 ohm bypass for use with regular amplifiers. High quality audio comes standard with the WP65BT, even at 6.5" the woofer is able to provide an extended low end. No matter what your next job is, the WP65BT is a great choice for excellent sound in a discrete, compact enclosure.
Multiple Mounting Configurations
The WP65BT comes complete with mounting brackets for pendant, wall, and landscape mounting. The multiple mount configurations along with 70V and 8 ohm option provides the ultimate flexibility in application and installation design
Pendant Mount
Mounting hardware includes a separate specialized end cap covering the transformer tap selection and phoenix wire connector with an eye bolt for connecting to a hanging device such as a steel safety cable.
Wall Mount
Mounting hardware includes a fully enclosed end cap protecting the transformer tap selection and phoenix wire connector. The speaker connects to a ball joint mount for both vertical and horizontal axis configuration.
Landscape Mount
Mounting hardware includes a fully enclosed end cap protecting the transformer tap selection and phoenix wire connector. The speaker connects to a ball joint mount which is attached to a landscape style stake providing sturdy support for the speaker
Dayton Audio DB8 Outdoor Burial Subwoofer
An Effortless Addition
The Dayton Audio DB8 8" outdoor burial subwoofer gives you the ability to add discrete low end to your outdoor audio system. Utilizing an 8" woofer with a polypropylene cone and rubber surround, the DB8 delivers massive outdoor bass. With the ability to handle up to a powerful 400 watts, the DB8 provides your outdoor audio system with earth rattling low end.
High Output
The port of the DB8 extends above ground, both extending the low frequency and directing the output exactly where you need it. Extra protection is provided with an installed mesh screen on top of the port to keep the elements and critters out.
High Protection
The enclosure of the DB8 is made of high-density ABS and sealed with an extra-rugged gasket to protect the high-output woofer inside. This protection measure also guarantees the enclosure will not leak and provide the full output without any losses.
Amplifiers and Accessories
Dayton Audio DTA-2.1BT2 Class-D Stereo Amplifier
The Dayton Audio DTA-2.1BT2 amplifier provides clean Class D power from an extremely compact and lightweight design. Enough power for most speakers and is also able to power a passive subwoofer. This allows you to create an inexpensive and high-performance 2.1 set up for any office, bedroom, or small home theater.
WPCC Waterproof Cable Connector
The Dayton Audio WPCC1 weather-tight cable/wire connector works to connect all Dayton Audio outdoor speakers' input wire with other speaker wire. Requiring no tools for assembly, the WPCC1's chuck-style wire grips and internal gaskets prevent the ingress of liquid while ensuring safe, reliable long-term connectivity.
14 AWG Direct Burial Underground Speaker Wire
This wire provides audiophile grade performance while standing up to harshest environments that effect many outdoor speaker installations. The cable features a specially formulated black polyethylene terephthalate film (PET) jacket that is UV resistant and the inner layer water tape provides protection against water damage. Its CL3 in wall rating works for inside, but it's more versatile UV resistant jacket makes it perfect for outdoors or burial.
Package Contents
  • 1x Dayton Audio DTA-2.1BT2 Class D Stereo Amplifier
  • 1x Pair of Dayton Audio WP4BT 4" Pendant Speakers
  • 1x Dayton Audio DB8 8" Outdoor Burial Subwoofer
  • 100ft 14AWG Direct Burial Speaker Wire
  • 1x Dayton Audio WPCC1 Outdoor Speaker Cable Connector
WP4BT Specifications:
  • Design: Indoor Outdoor Multi-Mount Pendants
  • Power Handling (MAX): 40 Watts
  • Frequency Response: 80-20,000 Hz
  • Impedance: 8Ω / 70V / 100V
  • 70V Taps: NC, 10, 5, 2.5, 1.5W
  • SPL: 87 dB / 88 dB @ 8 Ohms setting 2.83V/1m
  • Ingress Protection Rating: IP66
  • Dimensions: 5-3/8" H x 6-34" Dia.
  • Weight: 6.3 lbs. (each)
DB8 Specifications:
  • Driver: 8" polypropylene cone with rubber surround
  • Frequency Response: 25-300 Hz
  • Impedance:
  • SPL: 83 dB 2.83V/1m
  • Ingress Protection Rating: IPX5
  • Material: ABS
  • Dimensions: 28" H x 19.7" W x 15.6" D
  • Weight: 32.2 lbs. (each)
DTA2.1-BT2 Specifications:
  • Power Output: 50W @ 4Ohm
  • Subwoofer Output: 100W @ 8ohm
  • THD+N: <0.4% @ 50W
  • Subwoofer Low-Pass: 50-100Hz 12dB/oct
  • Frequency Response: 10Hz - 30kHz
  • Power Requirements: 120-240 VAC, 50/60Hz
  • Weight: 2.8 lbs
  • Dimensions: 5.1" W x 6" H x 1.5" D
Shop the Whole Pendant Line
WP4BT 4"
WP65BT 6-1/2"
WP65BTW 6-1/2"
  • Size: 4"
  • Color: Black
  • Sold As: Pairs
  • Size: 6-1/2"
  • Color: Black
  • Sold As: Pairs
  • Size: 6-1/2"
  • Color: White
  • Sold As: Pairs
WP8BT 8"
WP8WT 8"
  • Size: 8"
  • Color: Black
  • Sold As: Single
  • Size: 8"
  • Color: White
  • Sold As: Single
Shop All Indoor/Outdoor Speakers
IO Line
  • 70V/100V transformer with 8‑ohm bypass
  • Weather resistant ABS plastic enclosure and aluminum grills provide years of service
  • Available in 5‑1/4", 6‑1/2", and 8" versions in black and white
IOX Line
  • Passive radiator produces extended low‑end response for deep, tight bass uncharacteristic of outdoor speakers
  • Sealed IP66 ABS enclosure protects the speaker from the outdoor elements
  • Available in 6‑1/2" and 8" versions in black and white
Pendant Line
  • Versatile mounting brackets for pendant mounting, wall mount, or landscape applications
  • Integrated 70V transformer with selectable taps and 8‑ohm bypass
  • Suitable for indoor and outdoor installation
  • Available in 4", 6‑1/2", and 8" versions in black and white (4" only available in black)
    Outdoor Subs
    Add additional low-end with Dayton Audio’s indoor/outdoor subwoofers. With a burial and above-ground versions, the subs make adding bass extremely easy to any patio, pool, gardens, or landscaped audio. Both versions are compact and discrete to not disrupt your area’s aesthetics. Rugged and weather resistant design ensure a long-lasting life. The sub line delivers outstanding bass and value for any outdoor audio system
    Shop Now
    Part Number310-039
    UPC848864069326
    Weight59.7
    ColorBlack
    ConfigurationCoaxial
    Mounting StyleLandscape
    Woofer Diameter8"
