  • Shadow Mounts NBS-A Commercial Articulating TV Wall Mount 32"-80"
Shadow Mounts
Part #182-409
Shadow Mounts
Part #182-409
Model: NBS-A
The Shadow Mounts NBS-A is an excellent solution for mounting a 32"-80" television in a residential or commercial environment that requires a highly adjustable mount.
  • Safely secures a TV weighing up to 77 lbs. to a wall
  • Easily mount TVs with VESA patterns up to 600x400
  • Simple mounting makes installation a breeze
  • Sturdy steel construction allows for worry-free use for years to come
  • Allows for tilting of -20 to +10 degrees and 120 degrees of swivel
  • Provides extension up to 20.5" from the wall
Your Price: $39.98
MSRP: $54.99
Save $15.01 (27%)
Shadow Mounts' articulating TV provides an astounding amount of adjustability for your TV's position. The high-quality steel construction and included mounting hardware make the installation a breeze.
Specifications: • Supports 32"-80" flat-panel TVs • Weight capacity: Up to 77 lbs. • Supports VESA patterns up to 600x400 • Tilt: -20 to +10 degrees • Swivel: 120 degrees • Extension: 2.75" - 20.5" • Dimensions: 17" H x 26" W x 3" D.
BrandShadow Mounts
ModelNBS-A
Part Number182-409
UPC848791007682
Weight13.65
Mount StyleWall Mount
Mount TypeFull-Motion Articulating
TV Capacity75" and larger
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
