  • Dayton Audio ST603-4 60W Titanium Bullet Tweeter Pair
Dayton Audio
Part #275-403
Dayton Audio
Part #275-403
Model: ST603-4
The ST603-4 from Dayton Audio was designed to articulate and reinforce the high-frequency output of any professional loudspeaker. With a great price-to-performance ratio, you would be hard-pressed to find a better driver to keep on hand!
  • High sensitivity output designed for pro audio duty
  • 1" titanium diaphragm for a detailed response
  • Compact size to fit in the tightest spaces for smaller boxes
  • 6,100Hz crossover point is perfect for 3-way designs
  • Easily adds detail to any existing system
Your Price: $28.98
MSRP: $39.99
Save $11.01 (28%)
Quantity:Qty: 1-3 $28.98/ea
Quantity:Qty: 4+$26.08/ea
Order in the next 10 hr 33 min to ship today. Details
Dayton Audio ST603-4 60W Titanium Bullet Tweeter with Pair
Fantastic high-frequency performance, even better value
Key Specs:
  • Power Handling (RMS): 60 Watts
  • Power Handling (MAX): 120 Watts
  • Impedance: 4 Ω
  • Frequency Response: 5000Hz - 20kHz
  • Sensitivity: 106 dB 2.83V/1m
  • Voice Coil Diameter: 1"
Frequency Response & Impedance
The Dayton Audio ST602-4 is a supertweeter that can keep up with many midrange drivers. By taking advantage of its high-frequency response, you can add air and clarity to any PA system!
High Sensitivity
The Dayton Audio ST603-4 has a high sensitivity to keep up with the demands of live audio. An output sensitivity of 106dB means the ST603-4 can add detail to even the most sensitive PA cabinets. When installed, the high-frequency output of the ST603-8 provides a clear and airy experience for every audience member in the crowd!
High Value
Dayton Audio created the ST603-4 to provide a reliable replacement option with a response that comfortably integrates with existing designs, all at a great value. These features also put the speaker designer at an advantage, allowing for a large variety of possible combinations when choosing drivers for their own projects!
We've Got Your Back
Learn More
Shop all Dayton Audio HF Drivers
PRO NEO-8
  • Exit Diameter: 1"
  • Frequency Response: 2.6kHz - 20kHz
Shop Now
PRO-8
  • Exit Diameter: 1"
  • Frequency Response: 2.5kHz - 20kHz
Shop Now
ST601-4
  • Exit Diameter: 1"
  • Frequency Response: 5.2kHz - 20kHz
Shop Now
ST602-4
  • Exit Diameter: 1"
  • Frequency Response: 5.1kHz - 20kHz
Shop Now
ModelST603-4
Part Number275-403
UPC848791008665
Unit of MeasurePairs
Weight1.4
Diaphragm MaterialAluminum
Power Handling (RMS)60 Watts
