  • Dayton Audio SD315A-88 12" DVC Subwoofer
Dayton Audio
Part #295-488
Dayton Audio
Part #295-488
Model: SD315A-88
The Dayton Audio SD315A-88 12" subwoofer speaker is one of the best bang-for-the-buck low frequency drivers available today.
  • Works equally well in sealed or vented enclosures
  • Attractive gasket-less design
  • Long-life rubber surround for years of reliable service
  • Excellent bottom octave performance
Your Price: $79.98
MSRP: $94.99
Save $15.01 (16%)
Quantity:Qty: 1-3 $79.98/ea
Quantity:Qty: 4+$71.98/ea
Order in the next 0 hr 52 min to ship today. Details
Only 19 In Stock
More due any day
The Dayton Audio SD315A-88 12" subwoofer speaker is one of the best bang-for-the-buck low frequency drivers available today. Dayton Audio DVC Series woofers were designed to offer the maximum performance-per-dollar. The speakers feature poly coated paper cones, wide rubber surrounds, large dual 8 ohm voice coils, vented pole pieces, and bumped back plates. Their healthy Xmax, long-throw construction, and dual voice coils make them perfect for any economical yet high-performing subwoofer speaker system.
Note: This is a dual voice coil driver, 8 ohms per coil. Specifications measured with the voice coils wired in parallel for a 4 ohm load.
ModelSD315A-88
Part Number295-488
UPC844632088711
Weight10.3
Nominal Diameter12"
Bolt Circle Diameter11.96
Power Handling (RMS)120 Watts
Power Handling (MAX)240 Watts
Frequency Response24 to 2,000Hz
Sensitivity93.75dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)24.2Hz
DC Resistance (Re)3.1Ω
Voice Coil Inductance (Le)1.5mH
Mechanical Q (Qms)3.54
Electromagnetic Q (Qes)0.37
Total Q (Qts)0.33
Compliance Equivalent Volume (Vas)5.36ft³
Mechanical Compliance of Suspension (Cms)0.4mm/N
BL Product (BL)11.86T·m
Diaphragm Mass Inc. Airload (Mms)109.2g
Maximum Linear Excursion (Xmax)7mm
Surface Area of Cone (Sd)522.8cm²
Cone MaterialCoated Paper
Voice Coil FormerAluminum
Overall Outside Diameter12.36"
Baffle Cutout Diameter10.71"
Depth5.12"
# Mounting Holes5
Sealed Volume1.1ft³
Sealed F358Hz
Vented Volume2.3ft³
Vented F334Hz
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
