  • Dayton Audio RSS390HF-4 15" Reference Series HF Subwoofer 4 Ohm
Dayton Audio
Part #295-468
Dayton Audio
Part #295-468
Model: RSS390HF-4
Engineered to provide high-volume, low-distortion bass in larger rooms and other highly demanding applications, the Dayton Audio RSS390HF-4 15" Reference Series subwoofer speaker offers the perfect combination of high definition sound quality and low frequency impact.
  • Extensively vented motor eliminates compression and allows quiet excursion
  • Lightweight black anodized aluminum cone for rigidity and lower moving mass
  • Triple shorting ring motor for ultra-low distortion
  • 2-layer coil for reduced back EMF
  • Suitable for sealed or vented enclosures
  • Highest quality materials throughout for long-lasting performance
Your Price: $229.98
MSRP: $311.99
Save $82.01 (26%)
Quantity:Qty: 1-3 $229.98/ea
Quantity:Qty: 4+$219.35/ea
Estimated back in stock 6/27/2025
Alert Me When Available
The Dayton Audio Reference Series RSS390HF-4 15" speakers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low distortion. Second, third, and intermodulation distortion are kept extremely low by utilizing three magnetic short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look. Choose the high-fidelity version for home systems when you are looking for clean, low bass and are not restricted by cabinet size.
ModelRSS390HF-4
Part Number295-468
UPC844632055027
Weight30
Nominal Diameter15"
Power Handling (RMS)500 Watts
Frequency Response18 to 800Hz
Sensitivity91.2dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)19.5Hz
DC Resistance (Re)
Voice Coil Inductance (Le)0.92mH
Mechanical Q (Qms)3.02
Electromagnetic Q (Qes)0.5
Total Q (Qts)0.43
Compliance Equivalent Volume (Vas)7.49ft³
Mechanical Compliance of Suspension (Cms)0.22mm/N
BL Product (BL)15T·m
Diaphragm Mass Inc. Airload (Mms)306g
Maximum Linear Excursion (Xmax)14mm
Surface Area of Cone (Sd)829.6cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter15.29"
Baffle Cutout Diameter14.01"
Depth7.01"
Sealed Volume2.9ft³
Sealed F336Hz
Vented Volume3ft³
Vented F327Hz
