  • Dayton Audio RS75T-8 3" Reference Full-Range Driver Truncated Frame
Dayton Audio
Part #295-336
Dayton Audio
Part #295-336
Incorporating a low-distortion motor system with a copper ring, a copper cap, and an aluminum phase plug, the RS75T-8 can outperform "boutique" drivers that cost several times the price.
  • Truncated cast frame—great for line arrays and MTM speaker designs
  • Full-range performance
  • Low distortion and high resolution
  • Aluminum frame, aluminum cone, rubber surround
  • Distortion-reducing copper ring, copper cap, and aluminum phase plug
  • Subtle yet high-tech look makes a bold cosmetic statement
  • Designed and engineered in USA
Your Price: $29.98
MSRP: $41.99
Save $12.01 (29%)
Quantity:Qty: 1-3 $29.98/ea
Quantity:Qty: 4+$25.18/ea
Only 1 In Stock
More due any day
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Incorporating a low-distortion motor system with a copper ring, a copper cap, and an aluminum phase plug, the RS75T-8 can outperform "boutique" drivers that cost several times the price. The driver's truncated frame makes it ideal for line arrays and ultra-compact MTM designs requiring minimal driver-to-driver spacing. Its low-distortion characteristics and smooth response provide exceptional clarity, detail, and dynamics. Features a black anodized cone, heavy-duty 4-hole cast frame, low-loss rubber surround, and gold terminals.
ModelRS75T-8
Part Number295-336
UPC844632086274
Weight0.6
Nominal Diameter3"
Bolt Circle Diameter2.52
Power Handling (RMS)15 Watts
Power Handling (MAX)30 Watts
Frequency Response170 to 20,000Hz
Sensitivity84.3dB 2.83V/1m
Voice Coil Diameter0.63"
Resonant Frequency (Fs)189Hz
DC Resistance (Re)6.1Ω
Voice Coil Inductance (Le)0.32mH
Mechanical Q (Qms)5.84
Electromagnetic Q (Qes)1.13
Total Q (Qts)0.95
Compliance Equivalent Volume (Vas)0.01ft³
Mechanical Compliance of Suspension (Cms)0.69mm/N
BL Product (BL)2.58T·m
Diaphragm Mass Inc. Airload (Mms)1g
Maximum Linear Excursion (Xmax)1.3mm
Surface Area of Cone (Sd)12cm²
Cone MaterialAluminum
Overall Outside Diameter2.83"
Baffle Cutout Diameter2.13"
Depth1.52"
Sealed Volume0.02ft³
Sealed F3200Hz
Vented Volume0.07ft³
Vented F3108Hz
