  • Dayton Audio OS-2HD Outrigger Speaker Spike Set Heavy Duty with Black Steel Base 2 Pcs
Dayton Audio
Part #240-772
Dayton Audio
Part #240-772
Model: OS-2HD
Dayton Audio's OS-2HD heavy-duty outrigger set includes a black powder coated steel base for easy installation onto larger enclosures to give your DIY speakers a professional look while increasing stability. This outrigger set includes 2 steel bases with 4 spikes each and all the mounting hardware for installation.
  • Durable powder coated steel resists corrosion
  • Heavy-duty steel frame supports up to 200 lbs.
  • Includes both wood screws and threaded inserts for installation
  • Coupling loudspeakers to a floor can improve clarity, imaging, and bass response
Your Price: $49.98
Quantity:Qty: 1-9 $49.98/ea
Quantity:Qty: 10+$44.98/ea
Order in the next 0 hr 3 min to ship today. Details
Tall narrow speakers look great but tend to be a little top heavy, especially on carpeted surfaces. Just install Dayton Audio's OS-2HD heavy-duty outrigger set to the bottom of your enclosures to give them a wider footprint for increased stability. The black powder coated steel frame will give your speakers a professional look and make a solid base for the included spikes. The spiked feet pierce through carpet and padding making direct contact with the subfloor providing isolation along with extra stability. The spikes are also adjustable, making it easy to ensure that your speakers are level on any uneven surface. The OS-2HD outrigger set includes everything need for installation including 6 wood screws, 6 threaded inserts, and 6 matching machine screws.
Note: Dayton Audio OS-2HD Outriggers are sold in sets of 2.
Dimensions: 9/16" H x 15-5-8" W (minimum enclosure width: 7") x 13-3/4" D.
ModelOS-2HD
Part Number240-772
UPC848791006159
Weight4.05
Color / FinishBlack
Construction MaterialSteel
MONSTER DEAL
OF THE WEEK
$34.98 EACH
SAVE 22%
Lepai LP-168HA 2.1 2x40W Mini Amplifier + 1x68W Sub Output
