Dayton Audio NHP25Ti-4 1" Titanium Dome High Power Neodymium Tweeter 4 Ohm
- Extremely smooth response makes for easy transition to midrange diver
- Over 94 dB efficiency is perfect for use in higher output designs
- Attached heatsink and ferrofluid cooling for increased power handling
- Compact cast aluminum faceplate minimizes center-to-center distance
- High temperature neodymium motor allows high output for extended periods
We'll send you an email when Dayton Audio NHP25Ti-4 1" Titanium Dome High Power Neodymium Tweeter 4 Ohm is back in stock or available for preorder.
