  • Dayton Audio ND20FA-6 3/4" Soft Dome Neodymium Tweeter
Dayton Audio
Part #275-030
Dayton Audio
Part #275-030
Model: ND20FA-6
This versatile tweeter is a huge step above the average "budget" tweeter. It has the sensitivity, smoothness, and power handling to individually do a two-way with most small woofers.
  • Compact neodymium motors have low stray field
  • Ferrofluid enhances power handling and helps damp resonance
  • Front-mount pressfit design
  • Perfect for placement in car A-pillars
  • Center-to-center spacing as low as 1-3/4"
  • Extremely flat and extended response
Your Price: $10.98
MSRP: $23.99
Save $13.01 (54%)
Quantity:Qty: 1-3 $10.98/ea
Quantity:Qty: 4+$10.03/ea
Don't let the low price fool you! This versatile tweeter is a huge step above the average "budget" tweeter. Conceived with line array thoughts in mind, it is finally possible to achieve the inter-driver spacing needed to minimize comb filtering out to nearly 20 kHz. But its uses don't stop at line arrays-- it has the sensitivity, smoothness, and power handling to individually do a two-way with most small woofers. Or, use it in an A-pillar in your car as a great inexpensive component tweeter. Give them a try for your next budget or micro speaker-- you will be pleasantly surprised!
ModelND20FA-6
Part Number275-030
UPC844632000874
Weight0.1
Cone / Dome Diameter0.75"
Cutout Diameter1.30
Tweeter TypeSoft Dome
Power Handling (RMS)15 Watts
Frequency Response3,500 to 25,000Hz
Sensitivity90dB 2.83V/1m
Resonant Frequency (Fs)2005Hz
DC Resistance (Re)5.2Ω
Voice Coil Inductance (Le)0.05mH
Mechanical Q (Qms)1.5
Electromagnetic Q (Qes)2.88
Total Q (Qts)0.99
Overall Outside Diameter1.77"
Depth0.59"
