  • Dayton Audio ND105-PR 4" Aluminum Cone Passive Radiator
Dayton Audio
Part #290-213
Dayton Audio
Part #290-213
Model: ND105-PR
The Dayton Audio ND105-PR 4" passive radiator makes it easy to tune small enclosures lower without increasing overall enclosure size. With a one-piece aluminum cone, rubber surround, high excursion capability, and easily adjustable mass, this passive radiator is perfect for building extremely compact speaker systems capable of incredible low frequency output.
  • Rigid black anodized aluminum alloy cone
  • High excursion capability: 12 mm peak to peak
  • Same "family look" as ND Series woofers
  • Adjustable mass for a vast range of tuning frequencies
Your Price: $8.99
MSRP: $18.99
Save $10.00 (53%)
Tune small enclosures with Dayton Audio's ND105-PR 4" passive radiator in speaker designs where a conventional port is not a viable option. This compact passive radiator includes all of the features you expect with larger radiators including high excursion capability, aluminum cone, rubber surround, and adjustable mass. Visually identical to Dayton Audio's popular ND series drivers, the ND105-PR can be used with any small speaker. The threaded rod and included wing nut on the back of the cone makes it easy to add mass to tune the radiator as needed for your projects. Whether you are building a multi-driver array, sound bar, or portable Bluetooth speaker, the Dayton Audio ND105-PR introduces a new range of possibilities.
The ND105-PR 4" passive radiator includes:
(1) Passive radiator
(1) 21.8 gram disk weights
(1) Wing nut
Specifications: • Fs: 51.5 Hz • Vas: 0.09 cu. ft. (2.6 liters) • Qms: 5.93 • Cms: 0.68 mm/N • Mms: 13.9g • Rms: 0.76 kg/s • Sd: 51.5 sq. cm. • Xmech: 6 mm • Dimensions: Overall diameter: 4.13", Cutout diameter: 3.66", Depth: 2.64".
Tip: As a general rule, the passive radiator(s) should have at least double the displacement of air (Vd) as the active woofer(s)/subwoofer(s) in the system.
To calculate Vd: Sd x Xmax = Vd
ModelND105-PR
Part Number290-213
UPC848791004841
Weight0.3
Nominal Diameter4"
Resonant Frequency (Fs)51.5Hz
Mechanical Q (Qms)5.93
Compliance Equivalent Volume (Vas)0.09ft³
Mechanical Compliance of Suspension (Cms)0.68mm/N
Diaphragm Mass Inc. Airload (Mms)13.9g
Surface Area of Cone (Sd)51.5cm²
Cone MaterialAluminum
Overall Outside Diameter4.13"
Baffle Cutout Diameter3.66"
Depth2.64"
