  • Dayton Audio MK602X 6" 2-Way Bookshelf Speaker Pair
CLEARANCE Dayton Audio MK602X 6" 2-Way Bookshelf Speaker Pair
Dayton Audio
Part #300-469
Dayton Audio
Part #300-469
Model: MK602X
  • 6" Glass fiber woofer extends the low-frequency range for impressive bass without distorting the critical vocal range above 2kHz
  • 1" Silk dome tweeter delivers accurate vocal and instrumental reproduction without the shrill peaks often found in metal tweeters
  • Wide dispersion means these speakers can be used in many locations without compromising your main listening position
  • Short signal path maintains the input signal quality, staying true to tone
  • 4 ohms impedance is compatible with most amplifiers
  • Faceted styling fits in any décor
  • 5 Year Warranty
Dayton Audio MK602X Bookshelf Speakers
The MK Series of home speakers from Dayton Audio are the best way to add rich sound with elegance and sophistication. Built to last, the MK series makes it easy to listen to for hours and hours with it non fatiguing sound. Enjoying audio has never been this easy.
Majestic Design
The MK602X are designed to look great wherever you install them. A classic textured black vinyl finish makes these speakers stand out on first glance and helps resists dust and dirt. The faceted baffle of the MK602X adds a geometric quality to the speaker and is designed to compensate for excessive treble, meaning your movies and music are true to tone, not tin. Sleek black fabric grills discretely obscure the drivers and can be easily removed. This design gives the MK series a premium look in addition to sounding fantastic.
Keynote Performance
The MK602X are engineered to disappear and deliver a transparent lifelike performance. Each speaker has an incredible wide listening field to provide excellent detail from any position. The unique faceted baffle on the front of each speaker does more than look beautiful, but actually help compensate for excessive treble, providing a smooth and non-fatiguing experience.
Detailed, Not Distracting
Designed for long-term listening sessions, the silk dome tweeter in the MK602X was selected for its low distortion and uniform dispersion characteristics. Because of their well-behaved off-axis response and excellent dispersion, the MK602X are less critical to position than most loudspeakers. Simply placing them where they best fit into the decorating scheme is all that is necessary for exceptional performance.
Felt, And Heard
"Do I need a sub?"
Probably not, and here's why; the high excursion of this woofer extends low frequencies and lowers distortion at higher output. Long story short, the MK602X can get loud, and is tonally balanced at all volumes for your favorite films.
  • Design: 2-way vented bookshelf
  • Woofer: 6" high excursion driver with a glass fiber cone
  • Tweeter: 1" soft dome
  • Finish: Black vinyl
  • Power handling: 60 watts RMS/120 watts max
  • Impedance: 4 ohms
  • Frequency response: 45 to 20,000 Hz
  • Sensitivity: 87 dB 1W/1m
  • Crossover: 2-Way 3.3kHz crossover with 2nd order slopes
  • Terminals: 5-way gold plated binding posts
  • Port tuning: 45 Hz
  • Dimensions: 12-3/4" H x 7-7/8" W x 8-3/4" D
We Got Your Back
Explore the Entire MK Series
This full selection of MK speakers includes bookshelf, floorstanding, a center channel and a subwoofer, making it easier than ever to get the most detail out of a two-channel or surround sound system.
MK402X
4" 2-Way Bookshelf Speakers
Shop Now
MK402BTX
Bluetooth 4" 2-Way Bookshelf Speakers
Shop Now
MK602X
6" 2-Way Bookshelf Speakers
Shop Now
MK442T
L4" Dual 2-Way Tower Speakers
Shop Now
MK442
4" Dual 2-Way Center Channel Speaker
Shop Now
MKSX4
Passive quad driver subwoofer
Shop Now
Featured Bundles
Due to their uniform look and sound MK Series Speakers can be easily combined to build a wide variety of systems. Add a subwoofer to your stereo pair for a extremely powerful low end, or completely upgrade your home theater experience with in immersive surround sound experience.
MK442 Cinema 5.1
When Combined, MK speakers create a wonderful cinematic experience. Every speaker in this system is designed in conjunction with one another to match both aesthetically and sonically.
Shop Now
MK602 Tube Stereo
The Dayton Audio HTA100BT is a perfect companion to the MK602X bookshelf speakers, and together with MK602X speakers you'll enjoy your favorite music for hours on end. Vintage tubes bring classic warmth and character to a modern stereo system with wireless Bluetooth streaming.
Shop Now
Build Your Own Portable MK Speaker
Utilizing the same drivers as the popular Dayton Audio MK Series, the MKBoom Bluetooth Speaker Kit is an incredibly versatile, great sounding DIY speaker. The easily assembled kit includes the drivers, the KAB amp board with the necessary accessories, port tubes, crossover boards, and the knock-down cabinets. Add a handle for a portable design making the MKBoom the perfect grab-n-go speaker for everyday use.
Need Inspiration? See What Others Have Built
Build by Michael C.
Build by Nick W.
ModelMK602X
Part Number300-469
UPC848791007811
Unit of MeasurePairs
Weight25.3
