  • Dayton Audio MK402X 4" 2-Way Bookshelf Speaker Pair
CLEARANCE Dayton Audio MK402X 4" 2-Way Bookshelf Speaker Pair
Dayton Audio
Part #300-465
Dayton Audio
Part #300-465
The Dayton Audio MK402X bookshelf speaker pair has the same amenities as the popular MK402 but an upgraded, more refined crossover delivers a smoother, non-fatiguing high-end. It features a 4'' woofer that extends to the low-frequency range and a 3/4'' tweeter that produces high frequencies with a wide dispersion. Amazing sound quality from a speaker this size gives more value for your money.
  • 4" treated-paper woofer extends the low-frequency range to play down to 60Hz range without hindering critical vocal range
  • 3/4'' tweeter delivers precise vocal and instrumental reproduction
  • Wide speaker dispersion range means these speakers can be used in myriad ways without compromising on sound quality
  • Short signal paths maintain the input signal quality
  • 4 ohms impedance is compatible with a range of amplifiers
  • Textured, black vinyl finish for an attractive look
Dayton Audio MK402X Bookshelf Speakers
The MK Series of home speakers from Dayton Audio are the best way to add rich sound with elegance and sophistication. Built to last, the MK series makes it easy to listen to for hours and hours with it non fatiguing sound. Enjoying audio has never been this easy.
The MK402X offers fantastic sound quality and articulation as the original but features a more refined crossover that produces smoother highs. Enhance your music listening experience with this pair of two-way vented bookshelf speakers.
Majestic Design
The MK402X features an attractive textured, black vinyl finish that stands out at first glance. The cabinet offers a unique geometric design for the baffle that sets it apart from much more basic speakers in its price range. The grill is removable and made of a high-quality black cloth that discretely obscures the most appealing features of this design, the drivers.
Keynote Performance
The MK402X are engineered to disappear and deliver a transparent lifelike performance. Each speaker has an incredible wide listening field to provide excellent detail from any position. The unique faceted baffle on the front of each speaker does more than look beautiful, but actually help compensate for excessive treble, providing a smooth and non-fatiguing experience.
Elegant 3/4" Silk Dome Tweeter
The 3/4" tweeter is elegant with a very airy top-end that can be appreciated by anybody that enjoys the delicate side of music that is often left behind by most speakers. The dispersion from this tweeter provides a life-like ambiance that truly sets a scene for the music.
Felt, And Heard
The woofer is able to play down to the 60 Hz range with ease. A 4" woofer playing low frequencies would normally limit the upper-frequency range, that is not the case here. The woofer plays through a large portion of the vocal range, adding coherency and smoothness to music.
Here's What Our Customers Are Saying
Highly recommend
"Puts out an impressive amount of sound for its size. Plays pretty flat down to 60hz, and will play notes quite a bit below that. Bass is certainly present and usually solid if sometimes a bit elastic or slightly bloated. Clear tweeter and decent sound stage. Enjoyable listening experience. Highly recommend for the price. Maybe the best budget speaker?" -Matthew G.
Don't Take Our Word For It
  • Design: 2-way vented bookshelf
  • Woofer: 4" high excursion driver with a treated paper cone
  • Tweeter: 3/4" soft dome
  • Finish: Black vinyl
  • Power handling: 40 watts RMS/80 watts max
  • Impedance: 4 ohms
  • Frequency response: 60 to 20,000 Hz
  • Sensitivity: 84 dB 1W/1m
  • Crossover: 2-Way 3.3kHz crossover with 2nd order slopes
  • Terminals: 5-way gold plated binding posts
  • Port tuning: 50 Hz
  • Dimensions: 9-1/2" H x 5-3/4" W x 6-5/8" D
We Got Your Back
Explore the Entire MK Series
This full selection of MK speakers includes bookshelf, floorstanding, a center channel and a subwoofer, making it easier than ever to get the most detail out of a two-channel or surround sound system.
MK402X
4" 2-Way Bookshelf Speakers
Shop Now
MK402BTX
Bluetooth 4" 2-Way Bookshelf Speakers
Shop Now
MK602X
6" 2-Way Bookshelf Speakers
Shop Now
MK442T
L4" Dual 2-Way Tower Speakers
Shop Now
MK442
4" Dual 2-Way Center Channel Speaker
Shop Now
MKSX4
Passive quad driver subwoofer
Shop Now
Featured Bundles
Due to their uniform look and sound MK Series Speakers can be easily combined to build a wide variety of systems. Add a subwoofer to your stereo pair for a extremely powerful low end, or completely upgrade your home theater experience with in immersive surround sound experience.
MK442 Cinema 5.1
When Combined, MK speakers create a wonderful cinematic experience. Every speaker in this system is designed in conjunction with one another to match both aesthetically and sonically.
Shop Now
MK602 Tube Stereo
The Dayton Audio HTA100BT is a perfect companion to the MK602X bookshelf speakers, and together with MK602X speakers you'll enjoy your favorite music for hours on end. Vintage tubes bring classic warmth and character to a modern stereo system with wireless Bluetooth streaming.
Shop Now
Build Your Own Portable MK Speaker
Utilizing the same drivers as the popular Dayton Audio MK Series, the MKBoom Bluetooth Speaker Kit is an incredibly versatile, great sounding DIY speaker. The easily assembled kit includes the drivers, the KAB amp board with the necessary accessories, port tubes, crossover boards, and the knock-down cabinets. Add a handle for a portable design making the MKBoom the perfect grab-n-go speaker for everyday use.
Need Inspiration? See What Others Have Built
Build by Michael C.
Build by Nick W.
ModelMK402X
Part Number300-465
UPC848791005916
Unit of MeasurePairs
Weight10.3
ColorBlack
Configuration2-way
Input Rating4 ohm
Woofer Diameter4"
