  • Dayton Audio MB620-8 6-1/2" Professional High Power Midbass Driver 8 Ohm
Dayton Audio
Part #295-635
Dayton Audio
Part #295-635
Built for high impact and low distortion, the MB620-8 6-1/2” midbass is a great choice for use in dynamic, high output 2-way and 3-way designs. With a damped paper cone, treated cloth spider, and powerful ferrite motor these drivers will deliver incredible clarity and detail even when pushed to extreme SPL levels. Suitable for use in professional speakers, studio monitors, and even car audio systems, these are incredibly flexible mid-bass drivers.
  • 94dB sensitivity and 200 watt continuous power handling allows incredible output
  • 2” voice coil and 30 oz ferrite magnet
  • Lightweight paper cone and cloth surround
  • Wide 100Hz-7kHz usable frequency response
  • Great for 2 or 3-way pro audio, car, or home hi-fi systems
  • Excellent choice for use in instrument applications
Your Price: $39.98
MSRP: $53.99
Save $14.01 (26%)
Quantity:Qty: 1-3 $39.98/ea
Quantity:Qty: 4+$35.98/ea
85In Stock
Dayton Audio’s MB620-8 6-1/2” professional mid-bass driver is engineered to provide maximum impact output while keeping distortion to a minimum. This mid-bass uses a powerful, ferrite magnetic motor and lightweight paper cone with cloth surround to achieve high SPL and loads of clarity. While optimized for 2-way pro audio systems, this driver is versatile enough for car audio and home hi-fi mid-bass work, and even musical instrument applications, such as bass guitar and keyboard. The MB620-8 is an 8 ohm 6-1/2” with a 2” voice coil and a 30oz ferrite magnet design. It offers a lot of bang-for-the-buck at 94dB SPL and 200 watts of continuous power handling. The MB620-8 has a wide and smooth usable frequency response from 100Hz-7kHz.
Dayton Audio MB620 6-1/2" Pro Midbass Woofer
Superior Detail Even When Pushed To The Extremes
Built for high impact and low distortion, the MB620-8-8 6-1/2" midbass is a great choice for use in dynamic, high output 2-way and 3-way designs. With a damped paper cone, treated cloth spider, and powerful ferrite motor these drivers will deliver incredible clarity and detail even when pushed to extreme SPL levels. Suitable for use in professional speakers, studio monitors, and even car audio systems, these are incredibly flexible mid-bass drivers.
Key Specs:
  • Nominal Diameter:  6-1/2"
  • Power Handling (RMS): 200 Watts
  • Power Handling (MAX): 400 Watts
  • Impedance: 8 Ω
  • Frequency Response: 100 - 7,000 Hz
  • Sensitivity: 94dB 2.83V/1m
  • Voice Coil Diameter: 2"
  • Maximum Linear Excursion: 2mm
  • Full Specifications   Manual
Wide Frequency Response
The MB620-8 has a wide and smooth usable frequency response from 100Hz-7kHz. This extended frequency range makes the MB620-8 great for a wide array of applications for pro, home, and car audio systems.
Lightweight Paper Cone and Cloth Surround
This mid-bass uses a powerful, ferrite magnetic motor and lightweight paper cone with cloth surround to achieve high SPL and loads of clarity.  The MB620-8 is an 8 ohm 6-1/2" with a 2" voice coil and a 30oz ferrite magnet design. It offers a lot of bang-for-the-buck at 94dB SPL and 200 watts of continuous power handling.
Incredibly Flexible Midbass Drivers
The MB620-8 6-1/2" midbass is a great choice for use in dynamic, high output 2-way and 3-way designs. While optimized for 2-way pro audio systems, this driver is versatile enough for car audio and home hi-fi mid-bass work, and even musical instrument applications, such as bass guitar and keyboard.
Great For:
  • Professional Speakers
  • Studio Monitors
  • Car Audio Systems
  • Home Hi-Fi Systems
  • Musical Instrument Amps
We've Got Your Back
Learn More
Shop the Whole MB Series
MB620 6-1/2"
  • Frequency Response: 100-7,000 Hz
  • Shop Now
MB820 8"
  • Nominal Diameter: 8"
  • Frequency Response: 100-7,500 Hz
  • Shop Now
MB1025 10"
  • Nominal Diameter: 10"
  • Frequency Response: 60-5,500Hz
  • Shop Now
Show Off Your Builds
We would love to see what you can build. Show off your creativity and skills by uploading to our project gallery.
For inspiration, see what others have built below:
Submit your projects to receive a 6-month digital subscription to audioXpress magazine
Additional Resources
Woofer Selection Guide
We've made it easier to find the woofer that fits your specific application, whatever that may be. This guide contains every woofer we carry, along with suggested optimum box dimensions, countless driver parameters, and more. All of this is contained in an easy-to-use, sortable guide to help you choose the perfect woofer.
Learn More
Woofer Replacement Tool
Easily replace damaged or worn out drivers in you speaker system to bring them back to their former glory. The Woofer Replacement Tools helps you determine the correct woofer to replace your current driver. This easy to use tool will get your speaker system back up and running quickly.
Learn More
Speaker Building Glossary
Build your speaker building knowledge with a vast glossary of all speaker and speaker building terminology you will encounter.
Learn More
Build Your Own Speaker
To answer some of the questions you may have concerning loudspeaker design that  takes you step by step through the build.
Learn More
THE Definitive Collection...The Speaker Building Bible
Through out the years, we have collected the best resources into the Speaker Building Bible. Click the link below to do a deep dive into speaker building.
ModelMB620-8
Part Number295-635
UPC848791008054
Weight6.3
Nominal Diameter6-1/2"
Bolt Circle Diameter6.15
Power Handling (RMS)200 Watts
Power Handling (MAX)400 Watts
Frequency Response100 to 7,000Hz
Sensitivity94dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)104Hz
DC Resistance (Re)5.47Ω
Voice Coil Inductance (Le)0.93mH
Mechanical Q (Qms)4.26
Electromagnetic Q (Qes)0.69
Total Q (Qts)0.55
Compliance Equivalent Volume (Vas)0.24ft³
Mechanical Compliance of Suspension (Cms)0.273mm/N
BL Product (BL)6.67T·m
Diaphragm Mass Inc. Airload (Mms)8.59g
Surface Area of Cone (Sd)132.2cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Overall Outside Diameter6.57"
Baffle Cutout Diameter5.8"
Depth3.15"
Sealed Volume0.2ft³
Sealed F3150Hz
Vented Volume0.4ft³
Vented F376Hz
