  • Dayton Audio LBB-5EB Expansion Board for LBB series Battery Boards
Dayton Audio
Part #325-140
Dayton Audio
Part #325-140
Model: LBB-5EB
Extend your power input and add 5 VDC USB output to 5-cell Dayton Audio battery boards with the LBB-5EB expansion board. It works with Dayton Audio LBB-5 and LBB-5S 5-cell lithium battery holder/charging boards.
  • Adds external charging input/output capabilities
  • 5 VDC 2A output charging power for smartphones
  • Plugs directly into the LBB series battery boards with included 6-pin 8" wiring harness
  • Standard 2.1 x 5.5 mm DC coax jack for power input
  • Doesn't work with the first version of the LBB-3 battery board 325-200
Your Price: $8.99
MSRP: $9.99
Save $1.00 (10%)
Quantity:Qty: 1-3 $8.99/ea
Quantity:Qty: 4+$8.49/ea
Order in the next 3 hr 54 min to ship today. Details
The Dayton Audio LBB-5EB expansion board gives you an extra 2.1 x 5.5 mm power input jack, plus two USB-A ports for charging smartphones, tablets, and other 5 VDC devices. This enables you to charge LBB series Dayton Audio battery boards buried in a project, plus power or charge 5 VDC devices.
Mount the expansion board externally by drilling a 0.31" hole for the power jack, 0.19" hole for the LED and cutting a 0.62" H x 0.58" W hole for the USB ports. You'll also need two standoffs for the two 0.14" mounting holes that are spread 2.12" apart to center. Standoff height will depend on your panel thickness. The small 2.4" x 1.8" board includes a 6-pin 8" wiring harness that plugs directly J-28 socket on the LBB-5 battery board, J-9 on the LBB-5S battery board, J-1 on the LBB-6S battery board, and J-5 on the LBB-3v2 battery board.
ModelLBB-5EB
Part Number325-140
UPC848791007262
Weight0.1
Board TypeBattery & Power
