  • Dayton Audio KABD-SPF Function Cables for KABD Series
Dayton Audio
Part #325-117
Dayton Audio
Part #325-117
Model: KABD-SPF
These function cables offer additional options for customizing Dayton Audio KABD Bluetooth amp board sound projects.
  • 3.5 mm AUX-in cable with jack provides a way to play music with non-Bluetooth devices
  • Four external potentiometers with cables and knobs for sound customization
  • Battery cable for true portable projects
  • External LEDs for Bluetooth and source status
  • Switch for power on/off or mute to increase battery life
  • 6-pin Aux-out cable for additional amplifier option
  • External stick on antenna to mount outside metal enclosures
Your Price: $9.49
MSRP: $14.99
Save $5.50 (37%)
Quantity:Qty: 1-3 $9.49/ea
Quantity:Qty: 4+$8.99/ea
Order in the next 3 hr 17 min to ship today. Details
Use the KABD-SFC cables to customize any Dayton Audio KABD project. This cable kit comes equipped with JST 2.0 PH connectors for easy termination to the board.
• The 20" AUX-in cable with 3.5 mm jack feeds music from any analog source directly to the Dayton Audio KABD boards, enabling audio play from almost any non-Bluetooth source.
• The volume controls with 8" cable and knob lets you manually control sound levels, and mounts into a 0.3" hole.
• The 4-pin 8" battery cable is for portable projects where AC or 12 VDC car power are not available. This cable plugs directly into LBB battery boards for quick installation.
• Using the 2-pin on/off or Mute 20" cable cuts power or mutes the board depending on which two terminals you connect to the 3-pin socket.
• The Bluetooth and source indicator LEDs come with a 20" cable to give you plenty of room to mount them externally.
• If you expand your project to 2.1 use the 8" 6-pin Aux-out cable to add another amplifier. The two outer pins are left and right channel and the two center pins are the ground for each channel.
• Use the external antenna with 4-1/2" cable only if mounting the KABD board in a metal enclosure. The on-board antenna has excellent range with most other enclosures.
ModelKABD-SPF
Part Number325-117
UPC848791007941
Weight0.2
Board TypeWiring Harness
