Dayton Audio KAB-2150 2 x 150W Class D Bluetooth 5.0 Amplifier Board with Tone and Volume Controls
- External volume, Bass, and treble controls let you customize sound right out of the box
- Plug-N-Play JST-PH and Molex Mini-Fit type wire harnesses make installation quick and simple with no soldering required
- Bluetooth 5.0 built directly into board -- no need for a separate module
- Efficient 2 x 150 watts of power from the TPA-3255 amp chip
- Line input and line output wiring harnesses with 3.5 mm jacks let you instantly add other components to your project
- On board antenna jack for an external antenna for metal enclosure DIY projects
- 5-year Dayton Audio warranty
We'll send you an email when Dayton Audio KAB-2150 2 x 150W Class D Bluetooth 5.0 Amplifier Board with Tone and Volume Controls is back in stock or available for preorder.
