Use this full function, adjustable amplifier board with built-in DSP chip in endless audio applications that seem impossible to produce the right sound quality. So if you’re a hobbyist or manufacturer enjoy presetting this full functioning 1 x 100W DSP amplifier board to peak performance in your finished product. The DSPB-100 is also CE and FCC ready for certification purposes.
To add more channels and Bluetooth to a project, combine the DSPB-100 with a Dayton Audio KAB-250v3 amp board using wiring kit DSPB-EC (sold separately). Examples of applications include:
Portable Power Paths
For portable applications, there are three battery holder/charging boards which permit the connection of li-Ion rechargeable batteries to power the board. First is the Dayton Audio KAB-BE 3-cell 18650 battery holder/charger board that is the same size as the DSPB-100 and KAB-250v3 which makes it easy to stack the boards with standoffs. This battery board must use a 15 to 24 VDC power supply.
If you desire more wattage output, use the 5-cell 21 VDC Dayton Audio LBB-5S or LBB-5 board. They work with 5 to 24 VDC power supplies. The LBB-5S uses 18650 Li-Ion batteries, and the LBB-5 uses 26650 Li-Ion batteries which delivers more play time. These portable power sources are highly recommended since all three provide under/over voltage protection.
Please note: To achieve power output briefly plug in the recommended power supply into the battery boards after the batteries are installed or when the batteries are removed and reinstalled.
Package Includes
• One Dayton Audio DSPB-100 DSP Amplifier Board
• One 2-conductor power cable 20"
• One 4-conductor speaker cable 20"
• One 3.5 mm line-input cable 20"
• Power output (w/ 24 VDC power supply): 1 x 100W @ 2 ohms
• SNR: 88 dB 100W @ 2 ohm, THD+N=1%, 26 dB, A-weighting
• 100W @ 2 ohm, THD+N = 1%, 200 Hz
• THD+N: 0.05% 10W @ 2 ohm 200 HZ 26 dB
• Frequency response: 20 to 20,000 Hz (±3 dB)
• Impedance: 2-8 ohms
• Recommended power supply: 12 to 24 VDC, 4A
• Board mounting holes center to center spacing: 3.32" x 2.4" (84 x 61 mm)
• Hole diameter: 0.14" (3.5 mm)
• Dimensions: 3.6" L x 2.7" W x 0.9" H
