  • Dayton Audio DRFS1 1-3/8" x 1" Heavy-Duty Rubber Feet 4 Pcs.
Dayton Audio
Part #240-712
Dayton Audio
Part #240-712
Model: DRFS1
Dayton Audio DRFS1 heavy duty rubber feet protect your floors and loudspeaker systems, and include all mounting hardware for installation in cabinets up to 1" thick.
  • Perfect alternative to cone spikes on tile, stone, or wood floors
  • Interchangeable with Dayton Audio subwoofer systems and accessory spike kits
  • Super-dense 1-3/8" diameter by 1" high rubber feet are durable and never "squishy"
  • Hardware included for mounting in panels up to 1" thick
Your Price: $9.79
MSRP: $12.99
Save $3.20 (25%)
Quantity:Qty: 1-9 $9.79/ea
Quantity:Qty: 10+$8.81/ea
Spiking a speaker system is not always an option—if you have tile, stone, laminate, or even hardwood floors you would probably prefer a scratch-free alternative. The Dayton Audio DRFS1 rubber foot set provides four dense, strong rubber feet and all necessary mounting hardware. Installation of the rubber feet will protect both the speaker enclosure and the floor surface, while also reducing or eliminating subwoofer "creep".
The DRFS1 rubber feet are compatible with current versions of Dayton Audio subwoofer systems and interchangeable with Dayton Audio accessory metal cone spikes. M6 barbed insert nuts and threaded studs are included for mounting in cabinet walls up to 1" thick. Set includes four heavy-duty rubber feet, four 6 mm threaded barbed insert nuts, and four 6 mm truss head Phillips screws. Insert nut requires a 5/16" hole to be drilled in new cabinet prior to installation. • Foot dimensions: 1-3/8" diameter, 1" high.
ModelDRFS1
Part Number240-712
UPC844632092022
Weight0.5
Color / FinishBlack
Construction MaterialRubber
