  • Dayton Audio Thruster Audio Exciter 32mm 40W 4 Ohm DAEX32EP-4
Dayton Audio
Part #295-230
Dayton Audio
Part #295-230
Turn even large, rigid surfaces into speakers with the Dayton Audio DAEX32EP2-4 Thruster exciter. Thanks to the high mass and powerful neodymium motor, this 40 watt exciter can drive heavier surfaces such as drywall and plywood. In addition, when teamed up with a light weight material, the Thruster DAEX32EP-2 can deliver incredibly high efficiency and surprisingly wide bandwidth response. With its impressive capabilities, it opens up possibilities for unique and innovative audio solutions.
  • Robust, heavy-duty design with a 32 mm voice coil attached to a steel spider
  • Pre-applied 3M™ VHB™ adhesive for quick, secure installation
  • Rare-earth neodymium motor and a proprietary two-layer voice coil
  • 4-ohm impedance for use with small, Class D amplifiers
  • 40 watt RMS power handling for high output
Your Price: $19.98
MSRP: $29.99
Save $10.01 (33%)
Quantity:Qty: 1-3 $19.98/ea
Quantity:Qty: 4+$18.98/ea
371In Stock
Test the limits of your imagination and turn any surface into a great sounding speaker system
Surface exciter technology provides a universal, cost-effective alternative to loudspeakers, allowing for sound reproduction virtually anywhere it is desired. Exciters may be used in a host of DIY executions to easily add sound to an existing non-audio specific project or create a portable speaker system, try out the assortment of exciters offered by Dayton Audio!
Want to learn more about exciters? See our Exciters & Tactile Transducers Introduction Paper!
Key Specs:
Power Handling (RMS): 40 Watts
Power Handling (MAX): 80 Watts
Nominal Impedance: 4 Ω
Neodymium Motor
1/3rd octave smoothing - measurement taken with transducer adhered off-center on a 12" x 12" x ½" foam core board in an infinite baffle setup.
Note: This information is for comparison purposes only, the actual frequency response will depend on many factors of which the diaphragm being the greatest contributor.
Aural Excitement
Dayton Audio's DAEX32EP-4 Thruster exciter is built to turn large, thick, rigid surfaces into speakers. The 32 mm voice coil is attached to a high-strength spider for maximum restoring force when large amounts of power are applied, making it perfect for large glass panes, furniture, and surfaces that would normally resist the effects of an exciter! A neodymium magnet is employed to create maximum magnetic flux around the proprietary voice coil for increased sensitivity when compared to similar-sized exciters. In turn, this reduces power requirements and makes it possible to use very small audio amplifiers, without sacrificing total output.
We've Got Your Back
Learn More
Show Off Your Builds
We would love to see what you can build. Show off your creativity and skills by uploading to our project gallery.
For inspiration, see what others have built below:
Submit your projects to receive a 6-month digital subscription to audioXpress magazine
Shimmer Tree by Dan Fox
Shimmer Tree is an impressive six metre high tree-like sound and light sculpture controlled by the wind. As the listener wanders underneath, the directional sound and changing resonances envelope the listener in an evolving and meditative sound bath that responds to the environment. It has 12 branches and 12 large cymbals suspended above head height. Each cymbal is fitted with a tactile transducer, transforming it into a metallic resonator speaker.
SoundPhoto by David F Giroux
I started with a vibrant 12×24″ metal print of fireworks over the Madison, Wis. city skyline — the “Shake the Lake” show over Lake Monona. This is my own photo, in a high-resolution professional print directly on a sheet of polished aluminum with1.5″ inset metal frame on the back. I installed a Dayton audio 15w/ch amp and 2 Dayton exciters behind the panel. Power switch, volume control, and aux audio input mounted discreetly on the side.
Bertha by Matty Hughes
My new 192 Watt DIY DML panel build (Bertha)! At 20in x 22in each 1/4″ thick plexiglass panel is running at 4 ohm’s @ 96 Watts, exciters wired in a series-parallel configuration for each panel and powered by a HiFi 100W x 2 (200W) Bluetooth 5 amp with a 24V 10a power supply. A total of 8 Dayton Audio DAEX25FHE-4 Framed High Efficiency 25mm Exciters each 24W 4 Ohm were used for this DML build.
ModelDAEX32EP-4
Part Number295-230
UPC848791000928
Weight0.3
ApplicationFull-Range Exciter
Power Handling (RMS)40 Watts
