  • Dayton Audio Audio Exciter Pair 25mm 5W 8 Ohm DAEX25
Dayton Audio
Part #300-375
Dayton Audio
Part #300-375
Model: DAEX25
Dayton Audio DAEX25 Sound Exciters turn virtually any solid object into a speaker by vibrating it at speeds of up to 20,000 cycles per second. Test the limits of your imagination.
  • Turn any solid surface into a great sounding speaker system
  • Create a completely hidden surround sound system
  • 3M adhesive pads for secure and fast placement
  • Wideband frequency response (dependent on attached material)
Your Price: $22.49
MSRP: $29.99
Save $7.50 (25%)
Quantity:Qty: 1-3 $22.49/ea
Quantity:Qty: 4+$20.24/ea
Order in the next 3 hr 2 min to ship today. Details
551In Stock
Dayton Audio DAEX25 Sound Exciter Pair
Dayton Audio DAEX25 turn virtually any solid object into a speaker by vibrating it at speeds of up to 20,000 cycles per second. The vibrations modulate the air, which is then decoded by the brain as sound. We've tested and placed Sound Exciters on nearly everything you can imagine; under a desk, in an overhead cabinet, behind picture frames, inside cans, behind paper plates, inside binders, cardboard, scraps of wood and even the box they came in! Test the limits of your imagination. Each stick on Sound Exciter is designed for a wide frequency response and great sensitivity. Built-in push terminals enable quick connection to speaker wire (sold separately). Strong 3M adhesive pads affix to nearly any solid surface for secure, long-lasting playback. Sold in pairs.
To learn more about Dayton Audio Exciters, and for help on which Exciter is right for you, check out Exciters & Tactile Transducers 101: An Introduction.
Check out Project Bike Stereo designed for a B.O.B. trailer featuring the Dayton Audio DAEX25 exciters and a Lepai amplifier!
  • Power handling: 5 watts RMS/10 watts max
  • Impedance: 8 ohms
  • Voice Coil Diameter: 1"
  • Re: 7.15
  • Le: 0.28 mH
  • Fs: 298 Hz
  • Dimensions: 3-1/2" dia. x 3/4"
ModelDAEX25
Part Number300-375
UPC844632070709
Unit of MeasurePairs
Weight0.35
ApplicationFull-Range Exciter
Power Handling (RMS)5 Watts
