  • Dayton Audio DA30 2 x 15W Class D Bridgeable Mini Amplifier
Dayton Audio
Part #300-330
Dayton Audio
Part #300-330
Model: DA30
Choose the Dayton Audio DA30 amplifier for your fixed audio application. Its small chassis fits away neatly for security, while the big sound fills classrooms and conference rooms.
  • 2 x 15W power output into 4 ohms or 1 x 30W bridged output into 8 ohms
  • Clear, articulate hi-fi sound quality, but built for the tough requirements of commercial duty
  • Cool-running Class D circuitry delivers high output while reducing AC line current demands
  • Ideal for classrooms, boardrooms, or bedrooms
  • Recessed, tamper-resistant tone controls provide simple sound shaping
  • Compact size makes it easy for this amp to fit almost anywhere
  • Add a Bluetooth receiver (sold separately) for even greater control flexibility!
Your Price: $92.98
MSRP: $131.99
Save $39.01 (30%)
Dayton Audio's DA30 is the ideal amplifier for commercial audio installations such as classrooms or offices, where a small, low wattage power amp is required. This palm-sized Class D amplifier sits inconspicuously on a desktop, and can also be installed on walls or under cabinets by using the included brackets. Perfect for powering ancillary zones in large setups, or mounted on or near a video projector!
The DA30 delivers 15 watts per channel in stereo mode and 30 watts when bridged mono. Two stereo audio inputs increase versatility: dual RCA or a single 3.5 mm TRS jack. Separate treble and bass controls allow the sound to be tailored to the room. The DA30's auto-on feature increases energy efficiency. An all-metal chassis and the selection of high-spec internal components ensure reliable operation and a long service life.
Specifications: • Power output: 2 x 15W RMS into 4 ohms, 1 x 30W into 8 ohms • Efficiency: 92% • Total harmonic distortion: 0.015% 20-20,000 Hz • Bass/treble turnover: 100 Hz/10,000 Hz • Input impedance: 100k ohms • Auto-on sensitivity: <0.8V • Stand-by current consumption: 0.6 mA • Power supply: 24 VDC, 2000 mA • Dimensions (H x W x D): 1-5/8" x 4-7/16" x 5-1/2".
With a Dayton Audio 5 year warranty, it’s more than a guarantee, it’s a promise. We stand behind our products and our warranty is a demonstration of our commitment to quality and reliability.
ModelDA30
Part Number300-330
UPC848791000317
Weight1.9
Power (RMS/Channel 8 ohms)0 - 25 Watts
Weight Range< 10 lbs.
