  • Dayton Audio DA115-8 4" Aluminum Cone Woofer
Dayton Audio
Part #295-328
Dayton Audio
Part #295-328
Model: DA115-8
The aluminum cone on this driver is extremely rigid yet well damped, making the bass and midbass region very clean and low in distortion.
  • Great looking and sounding woofer
  • Cosmetic stamped steel frame
  • Flat frequency response in passband region
  • Impressive output capabilities when used in MTM designs
  • Very low distortion
Your Price: $17.24
MSRP: $27.99
Save $10.75 (38%)
Order in the next 2 hr 53 min to ship today. Details
The aluminum cone on this driver is extremely rigid yet well damped, making the bass and midbass region very clean and low in distortion. When used with a well-designed crossover, an extremely flat frequency response can be achieved that is clean well into the midrange region.
ModelDA115-8
Part Number295-328
UPC844632081675
Weight2
Nominal Diameter4"
Bolt Circle Diameter4.21
Power Handling (RMS)20 Watts
Power Handling (MAX)40 Watts
Frequency Response60 to 15,000Hz
Sensitivity84.9dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)60Hz
DC Resistance (Re)6.4Ω
Voice Coil Inductance (Le)0.7mH
Mechanical Q (Qms)2.6
Electromagnetic Q (Qes)0.49
Total Q (Qts)0.41
Compliance Equivalent Volume (Vas)0.155ft³
Mechanical Compliance of Suspension (Cms)1.1mm/N
BL Product (BL)5.7T·m
Diaphragm Mass Inc. Airload (Mms)6.6g
Surface Area of Cone (Sd)53.1cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter4.55"
Baffle Cutout Diameter3.66"
Depth2.26"
Sealed Volume0.07ft³
Sealed F3134Hz
Vented Volume0.15ft³
Vented F363Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
