  • Dayton Audio Classic C40 Center Channel Speaker Black
Dayton Audio
Part #300-252
Dayton Audio
Part #300-252
The Classic C40 center channel speaker makes it easier than ever to hear dialogue. The unique 2-1/2 way crossover treats each 4” driver independently to create an extra wide listening experience for the whole family. Use the C40 with other speakers in the Classic Collection as part of a high-performance home theater system.
  • ULTRAWIDE COVERAGE – Custom multi-element crossover ensures a smooth transition between drivers and creates an excellent off-axis response
  • CRYSTAL CLEAR VOCALS – From the most noble monologues to a delicate whisper, the C40 Center Channel lets you hear every word with crystal clarity
  • WALL MOUNTABLE – Thanks to its keyhole mounting bracket and recessed binding posts, these speakers can be wall-mounted for space saving installations
  • SEALED CABINET DESIGN – the smaller speaker can fit in smaller spaces with accurate bass response
  • 4” BASS DRIVERS – Custom poly drivers paired with a well-built cabinet generate the perfect amount of bass in near-field applications
  • SILK DOME TWEETER – A large (1-inch) silk dome tweeter reproduces accurate treble in stunning detail without being harsh or abrasive
  • HIGH-QUALITY CONNECTIONS – Equipped with upgraded gold-plated binding posts, allowing the use of high-quality banana plug speaker cables for optimal signal transfer
Your Price: $45.98
MSRP: $99.00
Save $53.02 (54%)
The Classic C40 bookshelf speaker boasts an elegant cabinet design that houses all new Dayton Audio 4” bass drivers and a 1” silk dome tweeter. With a meticulously engineered and unique 2.5-way crossover, the Classic C40 creates an extraordinary theatrical experience, immersing listeners in rich, detailed sound that works in any home theater system.
4" Bass Drivers
Dual 4" poly bass drivers allow the C40 to play low in a compact package and are built to last for years.
Silk Dome Tweeters
1" tweeters provide clear distortion-free output in the vocal range and beyond, resulting in crisp clear sound.
Acoustic Suspension Cabinet
The sealed cabinet design provides a well-controlled low end and reduced bass distortion.
True Hi-Fi Design
The Classic C40 boasts a unique 2.5-way crossover design. A 2.5-way crossover helps eliminate muddy off-axis dialog, which haunts most common center channel designs. This allows listeners sitting off to the sides to experience the same crystal clear playback as the people directly in front of the speaker.
Designed From the Ground Up
The woofers and tweeters in the Classic Collection are purpose-built for this series, ensuring that each component is perfectly matched and optimized for the best possible performance.  This level of customization and precision engineering is rare in budget speakers, highlighting Dayton Audio’s dedication to delivering high-end sound
Huge Performance in a Tiny Package
The compact design of the Classic C40 speaker enhances its aesthetic appeal and greatly improves its overall versatility. The smaller cabinet allows the Classic C40 to be placed just about anywhere, allowing crystal-clear sound in almost any room. Additionally, the rear wall mounting brackets allow these to be wall-mounted under or above a TV.
Best In-Class Performance
The Dayton Audio Classic Collection stands out for its exceptional build quality and superior sound performance. Many similar speakers cut corners to reduce costs, often sacrificing sound quality and durability. In contrast, Dayton Audio maintains a high standard across all aspects of their speaker design, ensuring that even their most affordable models deliver top-notch performance. For anyone looking to enhance their audio experience without spending a fortune, the Dayton Audio Classic Collection is an outstanding choice that offers unbeatable value.
Commitment to Quality
High-quality binding posts are another feature that sets the Classic Collection apart from other budget speakers. These binding posts ensure a secure and stable connection between the speakers and the amplifier, minimizing signal loss and maintaining audio fidelity. The attention to detail in the design and construction of these binding posts reflects Dayton Audio’s commitment to quality and performance.
Removable Grills
The acoustically transparent grills provide a sleek and polished look, protecting the internal components while maintaining an elegant appearance. Remove the grills to expose the details of the front baffle and view the woofer and tweeter.  This combination of aesthetics and functionality makes the Classic Collection speakers a stylish addition to any audio setup.
Frequency Response70 - 20,000 Hz
Sensitivity
85 dB
Potential Output98 dB
Power Handling100W max (50W RMS)
Recommended Power Amplifier15 - 70 W
6 ohm
WooferDual 4" Poly
Tweeter1" Silk Dome
Enclosure Type2.5-way Acoustic Suspension
Crossover FrequencyLF 550Hz, MF/HF 3 kHz
Weight (each)
6.08 lbs. (2.76 kg)
Dimensions13 x 5.5 x 5.7 in. (330 x 140 x 145mm)
In The Box
  • 1 x Classic C40 Bookshelf Speaker
  • 1 x Speaker Grill
  • 4 x Adhesive Foam Feet
  • 1 x 10 ft. speaker wire
  • 1 x User Manual
ModelClassic C40-Black
Part Number300-252
UPC848791010361
Weight6.21
ColorBlack
Configuration2.5-Way
Input Rating6 ohm
Woofer Diameter4"
