  • Dayton Audio Classic B40A Powered Bluetooth Bookshelf Speaker Pair Wood
NEW Dayton Audio Classic B40A Powered Bluetooth Bookshelf Speaker Pair Wood
1 Question, 1 Answer or
Dayton Audio
Part #300-259
Dayton Audio
Part #300-259
Model: Classic B40A-Wood
Dayton Audio B40A Powered Bluetooth Bookshelf Speakers deliver powerful, room-filling sound in a compact design that blends vintage aesthetics with modern functionality. Featuring a 70W Class D amplifier, 4" poly woofers, and 1" silk dome tweeters with true Hi-Fi crossovers, these speakers provide exceptional audio clarity. With Bluetooth 5.0 and RCA inputs, they offer flexible connectivity for seamless playback from a variety of devices. Side-mounted tone and volume controls allow quick customization for an optimal listening experience.
  • Powerful Audio: 70 watts of RMS power delivers robust, room-filling sound.
  • Hi-Fi Components: Features custom 4" poly woofers and 1" silk dome tweeters for precise audio reproduction.
  • Versatile Connectivity: Equipped with Bluetooth 5.0 and RCA line inputs for easy device pairing and wired connections.
  • Vintage-Inspired Design: Classic two-tone vinyl finish and extended fabric grills complement any décor.
  • Side-Mounted Controls: Adjust bass, treble, and volume conveniently without accessing the rear panel.
  • Compact Build: Small footprint fits seamlessly into desktops, shelves, or tight spaces.
  • Complete Kit Included: Comes with speaker grills, adhesive foam feet, a 10 ft. speaker wire, and a user manual.
NEW $89.98
MSRP: $119.99
Save $30.01 (25%)
Order in the next 5 hr 2 min to ship today. Details
Dayton Audio Bluetooth Bookshelf Speakers, Powered, 70W, Wood (B40A)
Enjoy amazing sound with the Dayton Audio B40A Bluetooth Bookshelf Speakers. These speakers are small but powerful, with 70 watts of total power to fill your room with clear, vibrant sound. They feature a 4-inch woofer for deep bass, a 1-inch silk dome tweeter for crisp highs, and a high-fidelity crossover that makes everything sound balanced and smooth. Whether you’re listening to music, watching a movie, or playing a game, the B40A speakers are perfect for your setup.
Room Filling Sound
Dayton Audio engineered the B40A bookshelf speakers to produce full-range sound quality with their carefully crafted components. The 4-inch woofers bring deep, rich bass, making music and movies feel more exciting. The 1-inch tweeters add clear, sharp details, so you hear every word, note, and sound effect.
The speakers have a high-quality crossover. This crossover helps balance the low and high sounds from the woofers and tweeters. This creates a smooth shift between bass and treble, resulting in a balanced sound and a better listening experience.
Best In-Class Performance
Engineered in Dayton, Ohio, these powered speakers offer amazing sound. They use special Hi-Fi crossovers that optimize the frequency range of each driver. The result is a balanced, musical performance that exceeds expectations for tower speakers, home speakers, and more. Whether you’re setting up a home theater or just want better home speakers, these Bluetooth bookshelf speakers give you clear, balanced sound.
Timeless Design for Any Space
Part of the Dayton Audio Classic Collection, the B40A looks as good as it sounds. With a two-tone vinyl finish and extended fabric grilles, these speakers bring a mix of modern and vintage style to any room. They fit perfectly in a living room, bedroom, or home office. Their compact size makes them easy to place on shelves, desks, or entertainment centers.
Versatile Connections for Any Setup
You can set up the B40A bookshelf speakers in minutes thanks to their simple connection options:
  • Bluetooth Streaming: Stream wirelessly from any Bluetooth-enabled device for ultimate convenience.
  • RCA Line Input: Connect directly to turntables, TVs, computers, or other active and passive speakers.
Tailored to Your Sound Preference
The B40A speakers let you customize the sound to fit your style. Use the side-mounted knobs to adjust the volume, bass, and treble. Whether you want more bass for a party or softer treble for a relaxing night, it’s easy to make changes without any hassle. You can also adjust the settings effortlessly without needing to reach behind the speaker.
Powerful Performance with Room-Filling Audio
Equipped with a Class D amplifier and 70 watts of power per speaker, the B40A can fill your room with clear, vibrant sound. Whether you’re watching a movie with friends, working on a project, or just relaxing with music, these speakers bring your audio to life. They’re powerful enough for most spaces but small enough to fit just about anywhere.
Frequency Response75 - 20,000 Hz
Bluetooth Type
5.0
Potential Output95 dB
Power Output140W max (70W RMS)
AmplificationClass D
Passive Speaker Connection
Spring Loaded Terminals
Woofer4" Poly
Tweeter1" Silk Dome
Enclosure Type2-way Acoustic Suspension
Crossover Frequency5 kHz
Weight
4.5 lbs. (1.94 kg) Active
3.85 lbs. (1.74 kg) Passive
Dimensions5.5 x 9.5 x 5.7 in. (140 x 241 x 145 mm)
In The Box
  • Active B40A Bookshelf Speaker
  • Passive B40A Speaker
  • 2 x Speaker Grills
  • 8 x Adhesive Foam Feet
  • 10 ft. speaker wire
  • 6 ft. power cord
  • 1 x User Manual
Why Choose Dayton Audio Bluetooth Bookshelf Speakers?
The Dayton Audio B40A Bluetooth Bookshelf Speakers are perfect for anyone who wants great sound without taking up too much space. They’re easy to set up, look great in any room, and deliver high-quality sound for music, movies, and more. Upgrade your audio experience today with the B40A!
ModelClassic B40A-Wood
Part Number300-259
UPC848791010392
Unit of MeasurePairs
Weight9.06
