  • Dayton Audio CX120-8 4" Coaxial Driver with 3/4" Silk Dome Tweeter 8 Ohm
Dayton Audio
Part #295-384
Dayton Audio
Part #295-384
With a natural sounding 3/4" soft dome tweeter concentrically mounted in a long throw poly cone 4" woofer Dayton Audio's CX120-8 will produce extremely smooth response on and off-axis while avoiding the phase and lobing issues associated with standard 2-way designs. This driver is perfect for compact designs, portable speakers, or even custom car audio systems.
  • Full-range with accurate bass and extended high frequency response
  • Coaxial mounted 3/4" silk dome tweeter
  • Open cast frame for improved air flow and minimal power compression
  • 4" curvilinear poly cone woofer with rubber half roll surround
Your Price: $32.98
MSRP: $42.99
Save $10.01 (23%)
Quantity:Qty: 1-3 $32.98/ea
Quantity:Qty: 4+$29.68/ea
223In Stock
The Dayton Audio CX120-8 is a full-range coaxial loudspeaker providing high quality sound in a very compact format featuring a 4" curved linear poly cone woofer mated with a 3/4" silk dome tweeter. The poly cone woofer provides a good balance between stiffness, low mass and damping making for a very natural sounding driver with a smooth frequency response. The silk dome tweeter provides detailed and clear high frequencies with minimal distortion. In addition, the optimized tweeter placement and flaring reduces the phase issues with the woofer that is commonplace with even the BIG brand coaxes. Designed for use as a full-range in a small bookshelf speaker, an extended range (i.e. midrange/tweeter) driver in a 3-way system, or even car audio systems.
4" Woofer:
• 1" voice coil wound on an aluminum former for high power handling
• Curved linear shaped poly cone provides a good balance between stiffness, low mass and damping making for a natural sounding driver with a smooth frequency response
• Optimized rubber surround for reduced break up in the midrange band
• Attractive rigid open cast frame cast frame to minimize reflections, resonances and improve air flow
• High energy ceramic magnet for greater cone control and improved efficiency
Specifications: • Power handling: 40 watts RMS/80 watts max • VCdia: 1" • Le: 0.62 mH • Impedance: 8 ohms • Re: 6.2 ohms • Frequency response: 90-5,500 Hz • Fs: 87.5 Hz • SPL: 88.5 dB 2.83V/1m • Vas: 0.10 ft³ (2.99 liters) • Qms: 2.89 • Qes: 0.57 • Qts: 0.48 • Xmax: 3.0 mm • Dimensions: Overall diameter: 4-3/4", Cutout diameter: 3-7/8", Depth: 2".
3/4" Tweeter:
• Silk dome provides detail and clarity of high frequencies
• Coaxially mounted to pole piece of woofer cone
• Optimized placement and trimmed flaring to reduce phase issue interaction with woofer
• Strong neodymium magnet
• Trimmed flared throat to minimize phase issues causing suck-out with woofer
• High pass filter required (not included)
Specifications: • Power handling: 20 watts RMS/40 watts max • VCdia: 3/4" • Le: 0.04 mH @ 10 kHz • Impedance: 8 ohms • Re: 5.6 ohms • Frequency response: 4,500-20,000 Hz • Fs: 2,745 Hz • SPL: 89.2 dB 2.83V/1m • Qms: 2.20 • Qes: 7.91 • Qts: 1.72.
ModelCX120-8
Part Number295-384
UPC848791003905
Weight1.95
Nominal Diameter4"
Bolt Circle Diameter4.313
Power Handling (RMS)40 Watts
Power Handling (MAX)80 Watts
Frequency Response90 to 20,000Hz
Sensitivity88.5dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)87.5Hz
DC Resistance (Re)6.22Ω
Voice Coil Inductance (Le)0.63mH
Mechanical Q (Qms)2.89
Electromagnetic Q (Qes)0.57
Total Q (Qts)0.48
Compliance Equivalent Volume (Vas)0.106ft³
Mechanical Compliance of Suspension (Cms)0.765mm/N
BL Product (BL)5.08T·m
Diaphragm Mass Inc. Airload (Mms)4.82g
Surface Area of Cone (Sd)52.51cm²
Cone MaterialPoly
Voice Coil Wire MaterialCCA
Voice Coil FormerAluminum
Overall Outside Diameter4.75"
Baffle Cutout Diameter3.875"
Depth2.5"
Sealed Volume0.07ft³
Sealed F3167Hz
Vented Volume0.2ft³
Vented F365Hz
