  • Dayton Audio CS620EC 6-1/2" 2-Way Enclosed Ceiling Speaker
CLEARANCE Dayton Audio CS620EC 6-1/2" 2-Way Enclosed Ceiling Speaker
Dayton Audio
Part #300-417
Dayton Audio
Part #300-417
Model: CS620EC
For large rooms, try these Dayton Audio CS620EC 6-1/2" enclosed ceiling speakers. If you have an attic with blown-in insulation, then these are your ideal ceiling speaker. System includes: one speaker, removable steel mesh grills, built-in mounting brackets, hardware, and installation instructions.
  • 6-1/2" black coated poly cone woofer with foam surround and dome tweeter
  • Mylar tweeter
  • Gold plated spring loaded speaker terminals
  • UL94 high temperature rating enclosure
  • Perfect for attics with blown-in insulation
The Dayton Audio CS620EC's dual slot ports tune the woofer to the enclosure for deeper bass reproduction. If you want to step up to a real sounding ceiling speaker the Dayton Audio CS620EC 6-1/2" ceiling speaker is the right choice for you. UL94 high temperature rated enclosure.
System includes: one speaker, removable steel mesh grills, built-in mounting brackets, hardware, and installation instructions. Sold individually.
*Note: Remove and discard the 1/8" perforated ring that connects the center "painting grill mask" and the outer "mounting template" before attempting to use the templates.
Specifications: • Woofer: 6-1/2" coated poly cone • Tweeter: 1" Mylar • Power handling: 25 watts RMS/50 watts max • Impedance: 8 ohms • Frequency response: 50-20,000 Hz • Dimensions: 11" dia. x 7" D • Cutout size: 9-9/16" dia.
ModelCS620EC
Part Number300-417
UPC844632000515
Weight6.55
Input Rating8 ohm
Mounting StyleIn-ceiling
Woofer Diameter6.5"
Special FeaturesEnclosed Back
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
