  • Dayton Audio CS620C 6-1/2" 2-Way Ceiling Speaker Pair
CLEARANCE Dayton Audio CS620C 6-1/2" 2-Way Ceiling Speaker Pair
Dayton Audio
Part #300-402
Dayton Audio
Part #300-402
Model: CS620C
Dayton Audio's CS620C 6-1/2" 2-way coaxial ceiling speakers are an easily-installed way to put high fidelity sound into less-than hospitable environments, especially those exposed to high moisture.
  • 6-1/2" carbon fiber woofer resists moisture better than most
  • Easy installation, whether new construction or existing structure
  • Add music to the kitchen, den, bath, or patio, turning your home into a relaxing retreat
  • Coaxially mounted 1" Mylar tweeter for crisp, clear HF response
  • 5-year warranty
Don't let the low cost fool you! These great sounding Dayton Audio CS620C 6-1/2" ceiling speakers are ideal for adding music to the kitchen, den, bath, or patio! They feature a weather-resistant 6-1/2" carbon fiber cone with butyl rubber surround, and a coaxially mounted 1" Mylar dome tweeter. Perfect for locations exposed to high moisture, these speakers can hold their own against most environments (although they not intended for immersion).
The Dayton Audio CS620C's retrofit design allows installation in both new and existing construction in just minutes. Sold in pairs, the system includes removable steel mesh grills, built-in mounting brackets, hardware, and installation instructions.
*Note: Remove and discard the 1/8" perforated ring that connects the center "painting grill mask" and the outer "mounting template" before attempting to use the templates.
Specifications: • Power handling: 25 watts RMS/50 watts max • Impedance: 8 ohms • Frequency response: 60-20,000 Hz • SPL: 88 dB 1W/1m • Dimensions: 8-1/2" dia. x 2-3/4" D • Cutout size: 7-3/8" dia. • Sold in pairs.
ModelCS620C
Part Number300-402
UPC844632000454
Unit of MeasurePairs
Weight6.3
Input Rating8 ohm
Mounting StyleIn-ceiling
Woofer Diameter6.5"
Special FeaturesWeather Resistant
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
