Dayton Audio CE Series CE38M-8 1-1/2" Mini Speaker Driver 8 Ohm
- Lightweight mylar diaphragm
- Rugged molded plastic frame
- Powerful neodymium magnet
- Light weight, low cost
The Commercial Engineering (CE) Series drivers from Dayton Audio provides engineers, designers, and integrators with a line of economical small drivers that fit the diverse range of applications found in consumer electronics and audio-enabled electronic projects.
The Dayton Audio CE38M-8 1-1/2” mini speaker features a feather-light and smooth-sounding Mylar diaphragm and a lightweight injection-molded plastic frame, making it great for portable electronics and headphones. The high sensitivity also enables it to be used as a speaker in kiosks, intercoms, displays, or electronic games, and the 8-ohm impedance works with most small audio amplifiers or line-level outputs. The round frame can be press-fit or glued in place.
Note: The Mylar diaphragm is very fragile. To prevent damage, avoid contact with the diaphragm when handling. This driver should be installed behind a grille.
Product Details | |
Brand | Dayton Audio |
Model | CE38M-8 |
Part Number | 285-129 |
UPC | 848791001093 |
Unit of Measure | Each |
Weight | 0.02 |
Product Specifications | |
Nominal Diameter | 1-1/2" |
Power Handling (RMS) | 0.25 Watts |
Power Handling (MAX) | 0.5 Watts |
Impedance | 8Ω |
Frequency Response | 190 to 20,000Hz |
Sensitivity | 75dB 2.83V/1m |
Voice Coil Diameter | 0.5" |
Thiele-Small Parameters | |
Resonant Frequency (Fs) | 191.8Hz |
DC Resistance (Re) | 7.72Ω |
Voice Coil Inductance (Le) | 0.17mH |
Mechanical Q (Qms) | 1.59 |
Electromagnetic Q (Qes) | 4.45 |
Total Q (Qts) | 1.17 |
Mechanical Compliance of Suspension (Cms) | 9.68mm/N |
BL Product (BL) | 0.39T·m |
Maximum Linear Excursion (Xmax) | 0.1mm |
Surface Area of Cone (Sd) | 4.9cm² |
Materials of Construction | |
Cone Material | Poly / Mylar Diaphragm |
Magnet Material | Neodymium |
Mounting Information | |
Overall Outside Diameter | 1.65" |
Baffle Cutout Diameter | 1.45" |
Depth | 0.3" |
