  • Dayton Audio BSK2 Dual Bass Shaker Couch Kit
Dayton Audio
Part #300-9025
Dayton Audio
Part #300-9025
Model: BSK2
Dayton Audio's BSK2 Dual Bass Shaker Couch Kit is a perfect solution adding a 4th dimension of sensory experience to your home theater. Complete with the Dayton Audio BSA-200 200W amplifier, two Dayton Audio BST-1 50W bass shakers, and speaker wire, the kit has all of the components you need to start feeling what you've been missing.
  • Powerful amplifier and bass shaker combo optimized to add earth shaking bass for movies, games, and music
  • Two Dayton Audio BST-1 Pro tactile transducers, each can handle up to 100 watts max
  • Dayton Audio BSA-200 amplifier with built in low pass filter provides plenty of power
  • Built-in USB port for powering 5V devices or use with wireless Dayton Audio Wave-Link technology
  • Includes two BST-1 50W bass shakers, BSA-200 200W amplifier, and 25' of speaker wire
Your Price: $374.98
MSRP: $435.86
Save $60.88 (14%)
Order in the next 0 hr 48 min to ship today. Details
The human ear has the ability to hear a wide range of sounds, however, some sound is simply too low to hear and must be felt through the body. Feeling this extremely low frequency sound adds a new dimension to your listening, gaming, and movie experiences.
With two Dayton Audio BST-1 Pro Bass Shakers and the powerful Dayton Audio BSA-200 Amplifier this package will ensure that you will be able to feel everything from high impact explosions in movies to the subtle feel of road surfaces in racing simulators. Unlike subwoofers, the BST-1 Bass Shaker will not overload your listening area with offensive SPL levels, and the perceived loudness improves listening at lower sound volumes. The two BST-1 Bass Shakers and a BSA-200 Amplifier package is perfect for adding powerful vibrations to a couch, two large chairs, or even a small raised platform.
The engineers at Dayton Audio designed the BST-1 Bass Shaker to reproduce accurate, tactile sensations from your music and movie sound tracks. When a BST-1 Bass Shaker is installed on a resonant surface, it increases the portion of tactile sound as being "felt" beyond what is normally produced by subwoofers and ordinary speakers. Conventional subwoofers are traditionally considered optimized when you can feel rather than hear the bass. By using a BST-1 Bass Shaker in your system, this goal becomes easier to achieve -- enabling the subwoofer to perform at a more natural sound level.
A specially formulated nylon/fiber spider and the selection of quality hardware components allow the BST-1's internal motor structure to not only outperform the competition but increase the product lifespan. Simply put, with a Dayton Audio BST-1 Bass Shaker you can count on years and years' worth of amazing blasts, shakes, rolls, rattles, rumbles, thumps, bangs, and bumps!
The Dayton Audio BSA-200 high power bass shaker amplifier is designed and built specifically to power tactile transducers but works equally as well as a dedicated subwoofer amplifier. Its small form factor makes it perfect for tight spaces, while the included brackets allow for vertical or horizontal mounting. The frequency and balance knobs let you dial in the desired crossover point and output, giving you total control over your set-up.
The Dayton Audio BSA-200 is rated at 110 watts RMS per channel into 2 ohms. In bridged mono mode, both amplifier channels are combined for high-power monaural output. The amplifier is rated at 230 watts RMS into a single 4 ohm load when bridged.
Manual and automatic on/off modes allow easy integration into automated systems and saves power when not in use. 5V USB power output is designed for use with the Dayton Audio Wave-Link wireless system (not included). The Wave-Link system can link up to five receivers per transmitter giving you ultimate flexibility with remote mounting options.
BSA-200 Amplifier Specifications:
Output power: 110 watts RMS per channel @ 2 ohms, 230 watts RMS @ 4 ohms (minimum impedance) bridged mono
Input sensitivity: 170 mV
Frequency response: 5-200 Hz +/- 3 dB
Variable low pass: 50-200 Hz
Total harmonic distortion (stereo): 1%, (mono): 0.05%
Signal to noise ratio: 91 dB @ 100 Hz A-weight
Power requirements: 110~240 VAC 50/60 Hz
Max power consumption: 313W • Stand-by power rating: 0.5W
Auto turn-on sensitivity: 10 mV
Remote: wired (12 ft. cable)
Dimensions: 2.5" H x 9.5" W x 8.5" D
BST-1 Bass Shaker Specifications:
Housing: High grade aluminum
Frequency response: 10-80 Hz
Fs (unmounted): 30 Hz
Impedance: 4 ohms
Power handling: 50 watts RMS (each)
Weight: 3.75 lbs
Dimensions: 5.75" dia x 2.5" H
Mounting holes: 5.5625" center to center
Speaker wire length: 25'
ModelBSK2
Part Number300-9025
UPC848864063270
Weight16.55
ApplicationLow Frequency Bass Shaker
Power Handling (RMS)50 Watts
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
