  • Dayton Audio BSA-200 Amp with 4 BST-1 Bass Shakers Bundle
Dayton Audio
Part #300-9020
Dayton Audio
Part #300-9020
Feel the bass! With 4 Dayton Audio BST-1 pro bass shakers bundled with the Dayton Audio BSA-200 bass shaker amplifier, this package has the raw power you need to add some serious rumble to your audio, video or gaming set-up.
  • Dayton Audio BSA-200 capable of 230 watts RMS provides plenty of power
  • 4 Dayton Audio BST-1 pro bass shakers each capable of up to 100 watts max
  • Feel earth shaking bass from your music, videos, and games like the pros
  • Dayton Audio BSA-200 capable of running stereo or mono for added wiring flexibility
Your Price: $414.98
MSRP: $571.99
Save $157.01 (27%)
With 4 Dayton Audio BST-1 Pro Bass Shakers and the powerful Dayton Audio BSA-200 Amplifier this package will ensure that your whole family will be able to feel everything from high impact explosions in movies to the subtle feel of road surfaces in racing simulators. Unlike subwoofers, the BST-1 Bass Shaker will not overload your listening area with offensive SPL levels, and the perceived loudness improves listening at lower sound volumes. With 4 BST-1 Bass Shakers and the BSA-200 Amplifier this package is perfect for adding powerful vibrations to 2 couches, 4 large chairs, or even a whole raised platform.
The engineers at Dayton Audio designed the BST-1 Bass Shaker to reproduce accurate, tactile sensations from your music and movie sound tracks. When a BST-1 Bass Shaker is installed on a resonant surface, it increases the portion of tactile sound as being "felt" beyond what is normally produced by subwoofers and ordinary speakers. Conventional subwoofers are traditionally considered optimized when you can feel rather than hear the bass. By using a BST-1 Bass Shaker in your system, this goal becomes easier to achieve -- enabling the subwoofer to perform at a more natural sound level.
A specially formulated nylon/fiber spider and the selection of quality hardware components allow the BST-1's internal motor structure to not only outperform the competition but increase the product lifespan. Simply put, with a Dayton Audio BST-1 Bass Shaker you can count on years and years' worth of amazing blasts, shakes, rolls, rattles, rumbles, thumps, bangs, and bumps!
The Dayton Audio BSA-200 high power bass shaker amplifier is designed and built specifically to power tactile transducers but works equally as well as a dedicated subwoofer amplifier. Its small form factor makes it perfect for tight spaces, while the included brackets allow for vertical or horizontal mounting. The frequency and balance knobs let you dial in the desired crossover point and output, giving you total control over your set-up.
The Dayton Audio BSA-200 is rated at 110 watts RMS per channel into 2 ohms. In bridged mono mode, both amplifier channels are combined for high-power monaural output. The amplifier is rated at 230 watts RMS into a single 4 ohm load when bridged.
Manual and automatic on/off modes allow easy integration into automated systems and saves power when not in use. 5V USB power output is designed for use with the Dayton Audio Wave-Link wireless system (not included). The Wave-Link system can link up to 5 receivers per transmitter giving you ultimate flexibility with remote mounting options.
Part Number300-9020
UPC848791005701
Weight19.85
ApplicationLow Frequency Bass Shaker
Power Handling (RMS)50 Watts
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
