Don't judge a speaker by its size! The Dayton Audio B452-AIR 4-1/2" bookshelf speaker is the smallest in the Dayton Audio family, but the sound is big. A newly-designed 4-1/2" polypropylene cone woofer with 4-layer voice coil achieves excellent balance and listenability when combined with the 1" AMT tweeter, for exceptionally rich and detailed sound from a small speaker. While cheap speakers use plastic enclosure parts to cut costs, the inexpensive B452-AIR uses a sturdy wood-composite cabinet that minimizes resonance and enhances warmth without sacrificing clarity.
The B452-AIR bookshelf speaker fits into a space only 5.5" wide and less than 6" deep, making it the perfect choice for desktop listening, or compact surround speakers in a home theater surround-sound system. A built-in keyhole wall hanger bracket makes it a breeze to wall-mount the B452-AIR in any desired location. For a room-filling listening experience with deeper bass that rivals larger full-sized speakers, the B452-AIR speaker also pairs perfectly with any of the excellent Dayton Audio powered subwoofers.
Anywhere you enjoy music, the balanced sound of the B452-AIRs add a new dimension of affordable enjoyment.
Specifications: • Woofer: 4-1/2" polypropylene cone with 4-layer voice coil • Tweeter: 1" AMT • Power handling: 30 watts RMS/60 watts max • Impedance: 6 ohms • Frequency response: 85-20,000 Hz • Sensitivity: 84 dB 1W/1m • Dimensions: 9.5" H x 5.5" W x 5.7" D.
If you are using these speakers in a home theater system, add the matching center channel.
