  • Dayton Audio B452 4-1/2" 2-Way Bookshelf Speaker Pair
CLEARANCE Dayton Audio B452 4-1/2" 2-Way Bookshelf Speaker Pair
Dayton Audio
Part #300-452
Dayton Audio
Part #300-452
Model: B452
The B452 bookshelf speaker may be the little brother to the larger B652 bookshelf speaker, but it packs a sonic punch! Try it on your desk, or as part of a compact, unobtrusive yet sweet-sounding surround sound system.
  • Compact, wall-mountable enclosure for unlimited applications
  • Perfect for home theater rears or stand-alone stereo use
  • 4-1/2" woofer and polycarbonate tweeter for full-range sound
  • Dense, stable wood-composite cabinet ensures sonic warmth and richness
  • Black ebony pica vinyl finish blends into any décor
  • Speaker wire included
Don't judge a speaker by its size! The Dayton Audio B452 4-1/2" bookshelf speaker is the smallest in the Dayton Audio family, but the sound is big. A newly-designed 4-1/2" polypropylene cone woofer with 4-layer voice coil achieves excellent balance and listenability when combined with the 5/8" ferrofluid-cooled polycarbonate tweeter, for surprisingly rich, detailed sound from a small, affordable speaker. While cheap speakers use plastic enclosure parts to cut costs, the inexpensive B452 uses a sturdy wood-composite cabinet that minimizes resonance and enhances warmth without sacrificing clarity.
The B452 bookshelf speaker fits into a space only 5.5" wide and less than 6" deep, making it the perfect choice for desktop listening, or compact surround speakers in a home theater surround-sound system. A built-in keyhole wall hanger bracket makes it a breeze to wall-mount the B452 in any desired location. For a room-filling listening experience with deeper bass that rivals larger full-sized speakers, the B452 speaker also pairs perfectly with any of the excellent Dayton Audio powered subwoofers.
Anywhere you enjoy music, the balanced sound of the B452s add a new dimension of affordable enjoyment.
Specifications: • Woofer: 4-1/2" polypropylene cone with 4-layer voice coil • Tweeter: 5/8" polycarbonate dome with ferrofluid cooling • Power handling: 30 watts RMS/60 watts max • Impedance: 6 ohms • Frequency response: 85-20,000 Hz • Sensitivity: 84 dB 1W/1m • Dimensions: 9.5" H x 5.5" W x 5.7" D.
"Speakers pack a punch at a bargin price" c|net Review- January 27, 2015
c|net Review- January 31, 2015
If you are using these speakers in a home theater system, add the matching center channel speaker for less than $30
ModelB452
Part Number300-452
UPC848791001796
Unit of MeasurePairs
Weight8.45
ColorBlack
Configuration2-way
Input Rating6 ohm
Woofer Diameter4.5"
