Dayton Audio APA102 Class D Stereo 60 WPC Amplifier Auto OnThe Dayton Audio APA102 high fidelity power amplifier switches sources and powers on (in auto-on mode) automatically when a source signal is detected. Two-sources, two-channels, and Class D topology make Dayton Audio's APA102 amplifier the heavyweight in its class. The APA102 features two pairs of RCA line level inputs and a loop-out from the second source to feed additional zones, receivers, or other devices. Use the APA102 for additional power when connected to a multi-zone audio system, or by itself to power a stereo speaker system.
The APA102 is rated at 75 watts RMS per channel into 4 ohms, and 60 watts RMS per channel into 8 ohms. In bridged mono mode, both amplifier channels are combined for high-power monaural output. The amplifier is rated at 160 watts RMS into a single 8 ohm load when bridged. Each amplifier output channel incorporates robust protection circuitry for reliability and safety. Rack ears are included.
Specifications: • Output power: 60 watts RMS @ 8 ohms, 75 watts RMS @ 4 ohms, 160 watts RMS @ 8 ohms (minimum impedance) bridged mono • Total harmonic distortion: <1.0% @ 1 kHz • Signal to noise ratio: 100 dB, A-weighted • Frequency response: 10-30,000 Hz +0.0 dB/-3.0 dB • Input sensitivity: 700 mV • Power: 120 VAC, 60 Hz, 1.7A • Dimensions: 16.9" W x 7.65" D x 2.15" H.
