  • Dayton Audio APA100 Class AB Stereo Amplifier 60 Watts Per Channel
CLEARANCE Dayton Audio APA100 Class AB Stereo Amplifier 60 Watts Per Channel
Dayton Audio
Part #300-590
Dayton Audio
Part #300-590
Model: APA100
Connect with the Dayton Audio APA100 amplifier and enjoy the convenience of auto-on and auto-source switching technology that makes playing your favorite music a breeze. Use this affordable, versatile amp when more power is needed in a multi-zone system, or in a powerful, audiophile-grade stereo hi-fi setup.
  • Delivers precise, uncolored audio power
  • Convenient auto-on and auto-source switching features
  • Dual stereo RCA line level inputs switch sources automatically
  • RCA stereo looping outputs to feed additional zone amplifier(s)
  • A/B speaker selector simplifies connectivity
  • 5-way binding posts on both sets of L/R speaker outputs
The Dayton Audio APA100 high fidelity power amplifier switches sources and powers on (in auto-on mode) automatically when a source signal is detected. Two-sources, two-channels, and Class AB topology make Dayton Audio's APA100 amplifier the heavyweight in its class. The APA100 features two pairs of RCA line level inputs and a loop-out from the second source to feed additional zones, receivers, or other devices. Use the APA100 for additional power when connected to a multi-zone audio system, or by itself to power a stereo speaker system.
The APA100 is rated at 75 watts RMS per channel into 4 ohms, and 60 watts RMS per channel into 8 ohms. In bridged mono mode, both amplifier channels are combined for high-power monaural output. The amplifier is rated at 160 watts RMS into a single 8 ohm load when bridged. Each amplifier output channel incorporates robust protection circuitry for reliability and safety.
Specifications: • Output power: 60 watts RMS @ 8 ohms, 75 watts RMS @ 4 ohms, 160 watts RMS @ 8 ohms (minimum impedance) bridged mono • Total harmonic distortion: <1.0% @ 1 kHz • Signal to noise ratio: 100 dB, A-weighted • Frequency response: 10-30,000 Hz +0.0 dB/-3.0 dB • Input sensitivity: 900 mV (50 watts @ 8 ohms) • Crosstalk: >70 dB @ 1,000 Hz • Power: 120 VAC, 60 Hz, 4.2A • Dimensions: 16.5" W x 8" D x 2.5" H.
c|net Review - March 2, 2016
ModelAPA100
Part Number300-590
UPC848791001703
Weight11.85
Power (RMS/Channel 8 ohms)51 - 100 Watts
Weight Range10 to 19 lbs.
    MONSTER DEAL
    OF THE WEEK
    $129.49 EACH
    SAVE $14
    Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
