  • Dayton Audio AMTPRO-4 Air Motion Transformer Tweeter 4 Ohm
Dayton Audio
Part #275-094
Dayton Audio
Part #275-094
Model: AMTPRO-4
The Dayton Audio AMTPRO-4 Air Motion Transformer is designed for professional audio and demanding high-fidelity applications in which high SPL demands combine with the need for detailed reproduction and musical finesse.
  • Folded Kapton ribbon diaphragm delivers clean, detailed, and highly dynamic output
  • Open back design permits dipole or chamber loading
  • Pro-level output and ruggedness for PA boxes, studio monitors, or high-efficiency home playback
Your Price: $89.99
MSRP: $214.99
Save $125.00 (58%)
Order in the next 0 hr 31 min to ship today. Details
Only 23 In Stock
More due any day
Dayton Audio's AMTPRO-4 model features an extremely large AMT diaphragm with an open-back design and powerful neodymium magnetic assembly. This combination produces high output and low distortion over a broad frequency range, while handling large amounts of amplifier power.
Perfect for use in PA loudspeakers, large-format studio monitors, custom cinema speakers, or extreme performance hi-fi loudspeakers, the AMTPRO-4 can easily be chamber-loaded or open-baffle loaded as required by a particular dipole application. Thanks to its ability to be crossed over as low as 800 Hz, the AMTPRO-4 driver is a uniquely effective solution for midrange reproduction as well as treble, and can even be used as a wide-bandwidth “mid-tweeter” driver.
Dayton Audio AMT (Air Motion Transformer) tweeters borrow technology from the original Heil Air Motion Transformer to provide ultra-clean, detailed, and dynamic treble output. The pleated ribbon diaphragm of an AMT provides a large acoustic radiating area condensed into a compact chassis, for extremely high SPL output, wide bandwidth, and improved power handling.
ModelAMTPRO-4
Part Number275-094
UPC848791000645
Weight2.65
Cutout Diameter2.83
Tweeter TypeAMT Air Motion Transformer
Power Handling (RMS)50 Watts
Frequency Response800 to 18,000Hz
Sensitivity94dB 2.83V/1m
Resonant Frequency (Fs)800Hz
DC Resistance (Re)3.96Ω
Voice Coil Inductance (Le)0.06mH
Total Q (Qts)4.12
Overall Outside Diameter7.87" x 3.94"
Depth1.42"
