  • Dayton Audio AMT Mini-8 Air Motion Transformer Tweeter 8 Ohm
Dayton Audio
Part #275-095
Dayton Audio
Part #275-095
Model: AMT Mini-8
Dayton Audio's AMT Mini-8 Air Motion Transformer tweeter adds clarity, transient speed, and musical finesse to almost any loudspeaker design. The AMT Mini-8's compact housing is easy to mount anywhere, and groundbreaking AMT technology enables high output from this tiny driver.
  • Advanced Air Motion Transformer design squeezes air
  • Folded Kapton ribbon diaphragm delivers clean, detailed, and highly dynamic output
  • Miniature design can be mounted virtually anywhere
  • Powerful, lightweight neodymium magnet structure for low distortion and high efficiency
  • Sonically similar to the best metal ribbon and planar tweeters
Your Price: $29.98
MSRP: $44.99
Save $15.01 (33%)
Quantity:Qty: 1-3 $29.98/ea
Quantity:Qty: 4+$27.22/ea
Order in the next 6 hr 57 min to ship today. Details
The Dayton Audio AMT Mini-8 model features a round housing and compact AMT element, for wide dispersion that easily replaces dome tweeters in retrofit or new design applications. The AMT Mini-8 is small enough to be used in compact satellite speakers, or installed in the center of a mid-woofer to create a full-bandwidth coaxial driver, or implemented in other ways -- including line arrays. The sealed rear chamber design of the AMT Mini-8 eliminates the need for a separate internal chamber in the loudspeaker enclosure.
Dayton Audio AMT (Air Motion Transformer) tweeters use groundbreaking transducer technology from the original Heil Air Motion Transformer to provide ultra-clean, detailed, and dynamic treble output. The pleated ribbon diaphragm of an AMT provides a large acoustic radiating area condensed into a compact chassis, for extremely high output and improved power handling.
ModelAMT Mini-8
Part Number275-095
UPC848791000652
Weight0.1278
Cutout Diameter1.59
Tweeter TypeAMT Air Motion Transformer
Power Handling (RMS)15 Watts
Frequency Response3,500 to 40,000Hz
Sensitivity88dB 2.83V/1m
Resonant Frequency (Fs)3500Hz
DC Resistance (Re)7.92Ω
Mechanical Q (Qms)1.86
Total Q (Qts)1.84
Overall Outside DiameterWith faceplate 2.25"
Depth0.91"
