  • DS18 PRO-DR250TI 1" Professional Compression Driver 8 Ohm 1-3/8"-18 TPI
DS18
Part #294-8132
DS18
Part #294-8132
Model: PRO-DR250TI
DS18's Pro-DR250TI 1" titanium compression driver is built for high output midrange response. This 8 ohm driver handles a whopping 200 watts RMS to deliver natural vocal reproduction even when driven to extreme levels. Frequency response is 600 Hz to 13,000 Hz so this high intensity driver will fill all of your mid frequency needs. The 2" titanium diaphragm will ensure long lasting use with recommended power.
  • Handles 200 watt RMS for dynamic response with extreme output capability
  • Large 2" titanium diaphragm delivers wide bandwidth while minimizing unwanted resonances
  • Rugged cast aluminum housing wicks away heat during long listening sessions
  • 1-3/8" - 18 TPI mount for installation onto many popular high frequency horns
Your Price: $34.95
Capable of producing enough midrange output to keep up with the highest SPL systems, the Pro-DR250Ti 1" titanium compression driver from DS18 is built for incredible sound quality and reliability. This high-power driver uses a large but lightweight 2" diameter titanium diaphragm and voice coil to handle 200 watts RMS while producing a natural vocal range with detail and accuracy. Driving the diaphragm is a powerful ferrite motor that creates enough force for high output with low distortion. This extreme construction gives the Pro-DR2 what it takes to produce high SPL midrange response.
Specifications: • Power handling: 200 watts RMS, 300 watts max • VCdia: 2" • Impedance: 8 ohms • Frequency response: 600-13,000 Hz • Recommended high pass crossover: 800 Hz • Sensitivity: 96 dB 1W/1m • Mount: 1-3/8" - 18 TPI • Dimensions: 4.4" dia. x 3.83" depth.
BrandDS18
ModelPRO-DR250TI
Part Number294-8132
UPC810005182553
Weight3
Diaphragm MaterialTitanium
Exit Diameter1"
Mounting Type1-3/8"-18 TPI
Power Handling (RMS)200 Watts
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
