DS18's PRO-H44/BK shallow 1" screw-on exponential horn is perfect for installations with minimal mounting depth. This horn has a controlled 45° x 45° dispersion to direct the sound right were you need it for pinpoint imaging. The reinforced ABS construction can support heavy compression drivers without issue. Finally, to accommodate most popular screw-on compression drivers, the PRO-H44/BK uses the standard 1-3/8"-18 TPI mount.
Specifications:• Horn type: Exponential • Throat diameter: 1" • Mounting type: 1-3/8"-18 TPI • Dimensions: 4.52" H x 4.52" W x 3" D • Cabinet cutout: 3.625" x 3.625".
